Airtel V-Fiber (VDSL) - Link Drop & Other Issues [HELP]
  • Replies Replies 381
  • Views Views 155,653
@wecaz Yes, I have noticed everything same as you have said.
What are you doing to do with it now?
Experienced members have advised to ignore the issues if they are not impacting.
It is not known if Huawei modems also have the same issues. (to be checked with other forum members)
Even if Huawei modems do not have issues, and I raise the issue with Airtel, Huawei modems are not in stock.
why you guys are sorting this to yourself? If there is stability issues complain to Airtel. let it be their headache after all we are paying premium to
Airtel for reliability and customer support naa? disconnection threat is best to solve most of problems with airtel.
@iglooo Airtel technician knows only checking line. They don't have knowledge on vdsl. I showed them disconnection on modem. Still they aren't accepting the fault.
@wecaz how many disconnects per day? Im using same modem beetel 777vr1. For me it is 5 to 10 times in a day. I reduced to 2mbps plan..still facing disconnects.
Have you tried escalating the issue to Nodal or Appellate Authority?
@manojrk yes i talked to nodal officer. They told same story.. Senior technician will visit and fix the problem. I think copper line can't give more speed and stability at sametime.
I'm syncing at 100+ Mbps and my connection is very stable. You can escalte it once again to Appellate Authority and request them to fix it for good or be prepared to lose you as a customer.
Nodal officer assured that within 2 days issue will be fixed. Currently I'm using Airtel as backup.
