Beetel 450 TC1 and BSNL Broadband wifi problem.
  • Thread starter Thread starter mandster
  • Replies Replies 42
  • Views Views 44,715
I have a wifi problem with 450 TC1. I'm on airtel. my wired connection seems to be working alright. my wifi on my laptop also seems to be alright though i'm not sure 100%. but my mobile iPhone 3g disconnects from wifi frequently. signal strength is also not consistent. i've posted the system log for wireless below. u can see that all is not well.3/13/2011 11:40:52> System Error: 64 PC: 800975303/13/2011 11:41:3> Last errorlog repeat 24 Times3/13/2011 11:41:3> System Error: 64 PC: 800973a03/13/2011 11:54:35> System Error: 64 PC: 800975303/13/2011 11:54:45> Last errorlog repeat 37 Times3/13/2011 11:54:45> System Error: ffffffff PC: 800973dc3/13/2011 11:54:45> System Error: 64 PC: 800975303/13/2011 12:1:17> Last errorlog repeat 46 Times3/13/2011 12:1:17> System Error: 64 PC: 800973a03/13/2011 12:21:20> System Error: 64 PC: 800975303/13/2011 12:21:32> Last errorlog repeat 23 Times3/13/2011 12:21:32> System Error: 64 PC: 800973a03/13/2011 12:41:35> System Error: 64 PC: 800975303/13/2011 12:41:47> Last errorlog repeat 23 Times3/13/2011 12:41:47> System Error: 64 PC: 800973a03/13/2011 13:1:50> System Error: 64 PC: 800975303/13/2011 13:2:2> Last errorlog repeat 23 Times3/13/2011 13:2:2> System Error: 64 PC: 800973a03/13/2011 13:22:5> System Error: 64 PC: 800975303/13/2011 13:22:17> Last errorlog repeat 23 Times3/13/2011 13:22:17> System Error: 64 PC: 800973a03/13/2011 13:42:20> System Error: 64 PC: 800975303/13/2011 13:42:32> Last errorlog repeat 23 Times3/13/2011 13:42:32> System Error: 64 PC: 800973a03/13/2011 14:2:35> System Error: 64 PC: 800975303/13/2011 14:2:47> Last errorlog repeat 24 Times3/13/2011 14:2:47> System Error: 64 PC: 800973a03/13/2011 14:22:50> System Error: 64 PC: 800975303/13/2011 14:23:1> Last errorlog repeat 23 Times3/13/2011 14:23:1> System Error: 64 PC: 800973a03/13/2011 14:43:4> System Error: 64 PC: 800975303/13/2011 14:43:15> Last errorlog repeat 22 Times3/13/2011 14:43:15> System Error: 64 PC: 800973a03/13/2011 15:3:18> System Error: 64 PC: 800975303/13/2011 15:3:29> Last errorlog repeat 24 Times3/13/2011 15:3:29> System Error: 64 PC: 800973a03/13/2011 15:23:32> System Error: 64 PC: 800975303/13/2011 15:23:43> Last errorlog repeat 23 Times3/13/2011 15:23:43> System Error: 64 PC: 800973a03/13/2011 15:43:47> System Error: 64 PC: 800975303/13/2011 15:43:57> Last errorlog repeat 22 Times3/13/2011 15:43:57> System Error: 64 PC: 800973a03/13/2011 16:4:0> System Error: 64 PC: 800975303/13/2011 16:4:11> Last errorlog repeat 23 Times3/13/2011 16:4:11> System Error: 64 PC: 800973a03/13/2011 16:24:14> System Error: 64 PC: 800975303/13/2011 16:24:25> Last errorlog repeat 22 Times3/13/2011 16:24:25> System Error: 64 PC: 800973a03/13/2011 16:44:28> System Error: 64 PC: 800975303/13/2011 16:44:39> Last errorlog repeat 24 Times3/13/2011 16:44:39> System Error: 64 PC: 800973a03/13/2011 17:4:42> System Error: 64 PC: 800975303/13/2011 17:4:53> Last errorlog repeat 30 Times3/13/2011 17:4:53> System Error: 64 PC: 800973a03/13/2011 19:20:40> System Error: 64 PC: 800975303/13/2011 19:20:52> Last errorlog repeat 44 Times3/13/2011 19:20:52> System Error: ffffffff PC: 800973dc3/13/2011 19:20:52> System Error: 64 PC: 800975303/13/2011 19:48:43> Last errorlog repeat 513 Times3/13/2011 19:48:43> System Error: 64 PC: 800973a03/13/2011 19:48:53> System Error: 64 PC: 800975303/13/2011 19:49:9> Last errorlog repeat 152 Times3/13/2011 19:49:9> System Error: ffffffff PC: 800973dc3/13/2011 19:49:9> System Error: 64 PC: 80097530i;m on firmware TM4-0Q-008.can anyone tell me what could be the problem and how to solve it.
i;m on firmware TM4-0Q-008. (* seems latest )
.1.
Uncheck box ADSL2+ in DSL page
( Re Check Statistics Adsl page
2.
Use wifi Channel 6 or 11.
3.
Position router at a higher height.
4
Keep router flat on table and rotate the unit for
Max signals at target area. Pattern figure of 8. antenna flat.
5.
If kept vertical pattern figure O
6
or get a dish type antenna to attach to wifi router. Focus in desired direction.
7
Mention OS used. If Windows 7 try application "Connectify" in laptop.
Feedback item wise.
thanks for the reply. however, i'm unable to access my modem now since the userid and password seem to have changed overnight. the userid was admin and password password. i did not reset it. is there anyway to access the modem now, without resetting it as resetting will involve configuring the modem again.btw, i'm using win xp.
If model supplied by Airtel PW is Password.
Iff supplied by BSNL PW admin
you can also try user PW password
or
support PW password.
essbebe, no luck.anyway thanks.will try to reset modem after finishing some important work as i don't want to be caught without internet in case of any problem in resetting.
After being in pain for almost a month I got it working finally. The problem was with the firmware. I installed the new firmware from 122.166.105.80 - /Firmwares/IPTV-FIRMWARE/FIRMWARE/BEETEL-450TC1/ .
TM4-0Q-020_20100628(With-Without CAS).rar
After installing the new firmware it allowed me to change the authentication type
and voila it connected.
Thanks for your help.
Cheers
Thanks a mandster and essbebe, Even i faced same issue with Beetel 450TC1, i had latest firmware TM4-0Q-025 which was not letting me to edit authentication type in wireless settings(which was disabled and customised for airtel broadband). i degraded the firmware to TM4-0Q-020 where i am able to edit it.
But even though i am not able to connect to internet. I am using windows 7 when i troubleshooted it windows says "DNS server not responding" i changed DNS server to openDNS server IP, dns server automatically , and with the DNS server IP's provided by BSNL but its no use :( what could be wrong. I am not able to ping any dns server 100% loss :( I tried uninstalling network adapter driver too. i am not using any VPN. Please help me i spent weekend in this without going anywhere :(
i degraded the firmware to{B] TM4-0Q-020{/B] where i am able to edit it.
In this model say You had selected PVC2 for bsnl vpi vci 0 35.
better to select all other PVC's and deactivate them..
Confirm you connect in PPPoE mode ( userid/PW entered in modem )
Confirm getting Internet in LAN mode.
screenshots etc if required.
2. Nice information about degrading FW to avoid default airtel ssid and key
( which are greyed ) Only one more SSID 2 key can be used/set. .
3. Carefully check boxes in WAN page. all boxes required to be activated are checked.
wait posting a screen shot.
wait....http://www.pcwintech.com/files/screenshots/beetel-450tc1/003.png
4. Click the PVC list for summary
How to select all other PVC's and deactivate them ?yes i am connecting with PPPoE mode and entered userid and password, i am getting the IP address from ISP too, but not able to connect through internet via LAN and WIFI :(
Just below each PVC activate /deactivate button is available.
Select one by one and deactivate them.
Back to PVC2 0 and 35
click the status bar for full summary.
please post connection status page.
screen shots if needed.
Start RUN type cmd Ok
new window
type ipconfig /all
copy paste only LAN DATA.
I deactivated all other PVC's except PVC2 0 and 35
status snapshot
Interface setup -> Internet snapshot
Diagnostic
Windows IP Configuration
Host Name . . . . . . . . . . . . : RDX-PC
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Realtek PCI GBE Family Controller
Physical Address. . . . . . . . . : 00-1A-4D-73-3F-C0
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::111c:4a70:4e19:10b8%35(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Lease Obtained. . . . . . . . . . : Monday, July 11, 2011 9:19:56 PM
Lease Expires . . . . . . . . . . : Thursday, July 14, 2011 9:45:04 PM
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 637540941
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-13-A3-7F-00-1A-4D-73-3F-C0
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 20:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{6222B038-64FA-46FC-8F53-28571307E4BD}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
you can see the LAN icon in taskbar it had yellow triangle.
I am not able to ping to any of the IP's other than 192.168.1.1 :(
Please help ASAP
Thanking You
