Best Wireless Routers for Home Use?
Hi, i have recently book Haathway's 50 Mbps plan, need a router for 3bhk flat with good signal strength, any suggestion for N-300 or N-600, budget range is 2-3 k.
Dear All, I am planning to buy wifi router for home use, Can you please recommend me best possible router..But it should meet following requirement... 1) Should have range to cover 3bhk or 1000 sqfeet 2)what is modem & without modem router...i have broadband connection which directly connect to the port which than require username password, so what type router shd i buy? 3)150mbps or 300mbps 4) please give me some suggestion and ideal price to buy...
Routers recommended in this thread:
Check D-Link DSL-2750U Deals on: Flipkart | Amazon
Check TP-Link TL-WR841N Deals on: Flipkart | Amazon
Check D-Link DIR-615 Deals on: Flipkart | Amazon
Check TP-LINK TL-MR3020 Deals on: Flipkart | Amazon
Check Netgear WGR614 Deals on: Flipkart | Amazon
Check TP-LINK TL-WR702N Deals on: Flipkart | Amazon
Edimax routers are exceptionally good and fast! I have almost 30 installed in my office + home!
For me, the best Wi-Fi router is D-Link DSL-2750U Wireless N 300. The router has been built with four Ethernet ports to keep connected to multiple networks to avoid interruption of workflow if any of those lines give way.
The issue with 2750U is, if we switch to ACT you have to muck around with firmware. I am also looking for a router since my 2750U died. Looking for a router that can work both as DSL and with ACT. So that I need not buy if I switch. Any recommendations?
Thank You
Sun
Finally purchase TP-LINK TL-WR841N 300Mbps Wireless N Router frm Flipkart.I m facing signal problem, i placed router in bedroom which is in corner but i m not getting signal in hall.wat would b exact problem?
hi i own the same router since a year or so and i am not facing any problem of range..i live on the 7th floor and i get wifi signal even in my society campus. u should place the router in the exact middle of your house. also the router should not be kept on ground and should not be surrounded by walls. try positioning it in abetter way and try..
^^ I purchased the D-Link DIR-816 for my Spectranet 100mbps FTTH. So far the router is only able to give 30-40mbps speed (as opposed to direct LAN connection where I get 100mbps).
