Best Wireless Routers for Home Use?
Yes. Read the review of the Netgear r6220 AC1200 in terms of wifi range and connectivity posted there. You should be getting full speeds via LAN and good speeds via wifi. @Zaphod got upgraded to 150 speeds recently as well, so perhaps can give us an update.
The D-Link 816 AC750 is not gigabit and so speeds will be capped to 100 mbps.
I have the R6220. I'm on 250 Mbps plan and the speeds I'm getting on 5 GHz are:
Router is in ground floor. 150 Mbps to 180 Mbps only when I'm closer to the router, ~ 60 Mbps to 90 Mbps anywhere in the ground floor. I'm able to access 2.4 GHz from first floor and the speeds are 20 Mbps to 30 Mbps. Range is average. Only reason I bought this is for the gigabit ports. Definitely not worth for it's current price @ 4.5K.
I managed to get a r6220 just for testing. As expected the wired desktop speed gets 150 but the wifi speeds are wanting - router is in the first floor, quite exposed and the speeds on the ground floor are 65 at best. I am ok with this but like @manojrk has pointed out, it is not worth 4.5K. So what are our options now? Do we compromise on wifi because the gigabit ports deliver promised speeds or is there a router that achieves both... I am sure there is, just that I dont know of them !!
@manojrk
Is there a way to set up 2.4 and 5 Ghz stuff? I know this is a noob question but how do we go about doing this... Can you point me in the right direction?
You need a gigabit router to get the speed you require on LAN. There are limited choices as far as gbit routers go. I wouldn't recommend the TP-Link one and the D-Link router has mixed reviews. 65/wifi on a different floor is a really good speed. This is the best router at your price range, the last time I looked it up, it was 3k, so I'd suggest you wait for Amazon to restock and for the price to drop.
Devices switch to 2.4 and 5ghz bands automatically according to the range of the signal.
Sure. Go to your router setup page and select the Wireless option under Basic.
You can leave the Channel in Auto on if you don't use Cordless telephones or another wifi router. Just enter your desired SSID and password for 2.4G and 5G and click apply. That's it.
@manojrk
So while connecting from a device you use the appropriate SSID?
Also tell me if my understanding is correct - 5GHZ delivers better speeds but poor range and vice versa for 2.4... hence the reason I am getting 140 on my ipad when I am on the same room as the router and I connect to the 5Ghz SSID !
@Jay
I agree, 60 is good. But I was just wondering what delivers those good speeds. Can you link me to some routers? This is more for learning rather than buying, so do let me know.
Also considering that speeds are only going to increase is it wiser to get a ac1600 or AC1900, what do you think in terms of future proofing? Also ac**** does not having anything to do with the wired LAN speed right, I guess as long as the router has a gigabit ethernet port we should get the promised speeds right? OR am I wrong?
And would you believe it if I told you that ACT sells it at 4.5K. For new customer who pay in bulk it is free and for customers like me who have been with them for 3 years, I have to pay much higher than the MRP. If not for their speeds man... really shady business practices
Yep. As you may have already noticed, 5GHz has much shorter range than 2.4GHz.
I used TP-Link Archer C9 AC1900 for a brief period before returning it. The range and speeds were only slightly better than R6220. I have heard good things about R7000 and Asus RT AC68U but they cost way more than R6220, prices are on par with enterprise grade routers/access points. Like Jay suggested this might be the only router with gigabit ports and wireless AC under 5K, sometimes goes on sale for 3K.
Yes and Yes. You will be getting the advertised speeds as long as the router has gigabit port.
I hope I am not hijacking someone's thread.
I am going to book DEN FTTH plan in Gurgaon and evaluating router options. DEN will provide 100mbps via a RJ45 LAN cable.
I have been using Linksys WRT54G since 2008 whenever ISP didn't provide a Wireless Router. I consider this opportunity to invest in a future-safe router. I have set following requirements:
- Budget around Rs. 3000-3500
- Excellent Signal Coverage (There is a wall between router and devices)
- Gigabit LAN (future-safe)
- Preferably with external antennae (past experiences)
- Warranty up to 3 year (D-Link offers)
- 802.11 AC (Wireless N is sufficient for now. I have phone supporting AC. Next laptop shall have AC too)
- AC 1200 mbps (Do I really need that much for being future-safe?)
- QoS bandwidth control for devices connected
- USB Port for printer sharing
(Don't have a printer for now, but good to have wireless printing)
- USB Port for 4G/3G Dongle (Optional)
I have found three routers that match quite closely:
TP-Link Archer C5 AC1200 Wireless Dual Band Gigabit Router
Netgear R6220 AC-1200 Smart WiFi Router with External Antennas
D-Link DIR-842 Wireless AC1200 Dual Band Gigabit Router
What do you guys say?
