Broad Band connection disconnecting and reconnecting every now and then.
  • Thread starter Thread starter bandurao
  • Replies Replies 27
  • Views Views 7,925
Hello friends,
i do have similar kind of problem. But i got confused whether the problem resides in my modem or BSNL.
here is my statistics. I can compare the one just posted above. But all the ratings are high for me. SNR and att.. etc
http://img224.imageshack.us/img224/6506/adslrd9.jpg
Here is the speed test result now
My Internet connection gets disconnected regularly and i have to manually log back in. Sometimes the connection doesn't break but the signals stop. :(
@/dhanjal/
Your modem UT300R2U
Open in IE 192.168.1.1/ Select DSL settings.
Select ONLY GDMT and enable bitswap.
Recheck snr/attn line speed etc.
Presume the modem page will look like this. ( same like Beetel 220BX)
http://i19.tinypic.com/6kqygzt.jpg
In a thread when two or more users have posted problems,
better to summarise your problem again.
Did you try opendns 208.67.220.220 and 208.67.222.222 ?
Also post the Device status page. Do you use a dialer ?
I have the same problem. Line gets disconnected after some time. SNR value is too low around 6-7, line attenuation is very high around 45-50. My tel was in another room, so after getting BB to bring the line to my computer room I joined the wire with another wire. May this be the problem? I told exchange several times to change the wire but nothing happens.
@essbeebee, One trend I notice for the past one week in my connections was that, the connectivity is very unstable till 5:00 PM and is normal/fast there after till the morning !!! Do you/others see this kind of trend in other cities/areas as well ?
Hello Guys,
I am still having the disconnection and reconnection problem.
Cab anyone tell me if below settings are correct or are there any unwanted settings ?
http://img401.imageshack.us/img401/2565/62273708ew3.gif
Also below is my speed test:
http://img144.imageshack.us/img144/5580/25838539nc4.gif
Also can anyone tell me how to REJECT the requests on unwanted ports of router:
http://img507.imageshack.us/img507/9687/32927718ba9.gif
Also Below is the Diagnostics of the Router, there are two test as FAIL, Dont know what are they and how to fix it.
http://img357.imageshack.us/img357/9089/10470321rd7.gif
Please help me to fix this disconnecting and reconnecting of the internet
:wall::wall::wall::wall::wall::wall:
