Broad Band connection disconnecting and reconnecting every now and then.
  • Thread starter Thread starter bandurao
  • Replies Replies 27
  • Views Views 7,924
Hey your settings are correct, they match the setting on my router as well. so it could be a problem with the line itself, ask them to change the cabling from pole
But there are two tests shown as failed, what are they and why are they failing. Is that affecting the connection ?:wall::wall::wall::wall::wall::wall::wall::wall::wall::wall:
SNR ---http://en.wikipedia.org/wiki/Signal-to-noise_ratiothis is the problem with u r pole where u r connection is there.....call the JTO and ask him to sit for an hour show him the problem ....that makes simple mate........don;t call the call center they just say it was fine ........
/member/bandurao/
1.Open your modem. status/statistics/adsl give snr attn line speed figures.
2. Uncheck in DSL settings all mod and keep only GDMT and try.
Mine for example:
Mode: ADSL2+
Line Coding: Trellis
On Status: No Defect Link
Power State: L0
Downstream Upstream
SNR Margin (dB): 31.7 18.7
Attenuation (dB): 12.0 19.4
Output Power (dBm): -14.4 1.4
Attainable Rate (Kbps): 26824 1399
Rate (Kbps): 2063 519
/member/bandurao/
Here is what you requested:
http://img529.imageshack.us/img529/4885/70579100ye4.gif
Hello Guys,
I have a problem about the broad band connection.
My internet connection is of 2MB speed but it keeps disconnecting and reconnecting every now and then. I am a web designer and my FTP software gets disconnected due to this. Due to this I cant upload heavy files as the connection will disconnect in few mins and again get reconnected.
I have called the BSNL office, they checked the phone line and also at their back end and they say everything is working fine.
I have also set the splitter which was not there before as the modem had direct phone line. I have read somewhere that splitter separates phone signal and internet signal. So I added splitter which did not helped atall.
Also the phone on that line is not used atall nor even the phone instrument is connected to line.
The line goes to splitter and from there to Modem.
I am in a big problem :wall::wall::wall::wall::wall::wall::wall::wall:
If you have any suggestions please let me know.
Dear Bandurao:
I too have faced a similar problem recently in Lucknow, U.P. due to heavy rains and windy days. BSNL guys at the Exchange level including the SDO are not tech savvy as far as broadband is concerned.
First, check the joints of your telephone line at the tel pole and anywhere else before the direct telephone line enters your splitter. If they are black in colour, that means there are carbon deposits. If they are black cut of the joints are refix them.
Second, examine the crimps. If you see anything black in there put in a new crimped cable.
Third, examine your splitter. Anything black in there? Maybe rain water has entered the splitter via the crimp cable - drop after drop. Change the splitter. Since BSNL does not sell splitters do not ask for one as they may give you a bad one. Buy an AirTel's Beetel ADSL Splitter. It costs just around Rs. 50. Mind you, it must be an ADSL Splitter.
Fourth, the splitter must not be further than 1-2 meters from your modem.
Finally, the line to your telephone instrument must emanate from the splitter. The other end must be connected to a BSNL/MTNL approved telephone instrument. AND, the telephone must be in working condition as this is ADSL2 connection and not DSL.
BSNL/MTNL will not give you an ADSL Broadband connection without you first booking and installing a telephone connection even if it is only incoming calls.
After the above, if you are still having problems then it maybe time to replace the telephone line or/and the modem provided by BSNL/MTNL. The modems have a life of 4 years. Do not go for another BSNL provided modem. Try Siemens. Do check the AC Adaptor of your modem and also that it is snuggly fitted to your UPS.
Thanks for the reply gspal, Today I had called the sub divisional engineer to my place to show how my internet applications get disconnected every now and then. Then I told him to change the whole cables from the pole but he said cables will affect only when there are joints in it. My connection is done on one piece so wiring is not at all a problem. Then also he cutoff the wires and reconnected them on the pole and told me to monitor the internet for one day. He said if it does not helps then we would be checking the internet connection from their main office where ports for internet are allocated on your phone lines. He also said that from there they can fire commands which tells them about the 8 parameters (technical language) of particular internet connection on which they come to know where is the problem. Now I have kept my finger crossed but I will posting here all the things I encounter so that if any of you have same problem you can contact your BSNL office and directly point out the things that they should check at thier end. :thumb:
