BSNL Broadband: How to Troubleshoot Frequent Disconnection
  • Thread starter Thread starter Deleted member 10390
  • Replies Replies 90
  • Views Views 59,533
Changed to G.DMT & after some time disconnection problem has been reduced thought I'll update again after extended use. CRC error have also reduced.
My telephone line has already been severed by a JCB machine thrice in last 6 months. I asked the lineman to give a new line but he says its unlikely that they will give a new line.
a. Will changing of LJU socket or splitter improve the situation?
b. I read in last page that some have problems with joint - what do joints refer to in this case?
c. I also read that one can ask the lineman to increase power or something - will it be helpful?
Thanks
After changing to G,DMT :
^ These latest stats look good enough.
Changing socket or splitter won't change anything especially if they're new ones. Try changing though, you never know.
Joints as in the number of joints in the external telephone wire. They should ideally be 0. Spend from your pocket and get a fresh one piece wire.
Lineman doesn't have a magic wand. What "power" is he going to increase?
I repeat: Stick with G.DMT.
What city/town are you from? PM me.
SNR (Downstream) 6.40 dB SNR (Upstream) 12.5 dB
my line man didn't provided telephone because stock is not there.
He connected wire directly to the My Wifi Modem.
There are some frequesnt disconnects in internet, not able to download 10mb file as connection loosing before completion of download.
How to increase SNR?
any other suggessions please
Me too have the frequent dropping of connections.
when working typical stat is as given below
ADSL Firmware Version​
FwVer:3.11.2.175_TC3086 HwVer:T14.F7_6.0
Line State​
Showtime
Modulation​
G.DMT
Annex Mode​
ANNEX_A Downstream Upstream
SNR Margin​
14.0 7.0 db
Line Attenuation​
32.5 20.5 db
Data Rate​
3040 416 kbps
Max Rate​
3808 556 kbps
POWER​
19.5 12.0 dbm
CRC​
2871 2948 But Downstream snr margin keeps fluctuating as high as 20 and as low as 2.1.It may hold or drop altogether.Then restart may take ages.At times broadband connected for hours without interruption and many times keeps connecting and disconnecting..While upstream is always constant why there is fluctuation on Downstream ? .Any guidance will be very much appreciated.
iChaitanya said:
Well, your downstream line attenuation is very good, but I don't understand why your downstream attainable rate is so low. There is some issue somewhere or maybe they've turned down the transmission power for your line.
What is ideal value of downstream attainable rate ?
see image.are SNR ,ATTENUATION,ATTINABLE RATE ETC are OK?
http://imageshack.us/photo/my-images/5/4mgh.png/
Uploaded with http://imageshack.us
Experiencing frequent disconnection since I shifted my connection to a new location. Linemen isn't able to understand the problem. Who should I talk to?
