Bsnl FTTH setup help for Tp Link XN020-G3v
  • Thread starter Thread starter brahul
  • Replies Replies 12
  • Views Views 8,913
I am using XN020-G3v in Rajasthan with BSNL FTTH 499 plan 300gb 40mbps. If you still need help, you can message me :)
Hey.. I did the same.. Bought TP-Link device with high hopes as device provided at installation didn't have proper wireless stability (innotech), however it wasn't my fault that it didn't work..
I asked the local provider about network details, showed him the device specs page.. He said, it will surely work nothing else to check..
Now it doesn't work, reason.. Guess what.. The OLT is EPON and not GPON.. Such a pain man..
Moreover he blames the device saying, LOS is blinking red it's device fault..
Well I'm not sure if the LOS will blink or not when type is EPON and not GPON that the device expects..
Not sure should I raise this for RMA or not.. No way to check.. any help here.. the device is wasted but b4 selling it on OLX just wanna be sure it's working..
Now they provided me with OptiLink, and that works much better than Innotech crappy device..
