bsnl fup page not loading not able to decline
After entering my username and password, it showed nothing except Amazon prime offer and some other thing. And the menu button has only home option and no data usage option.
Tilt your phone in landscape mode and you will see 3 dots menu option, from this click check usage. Or open in PC
Why is usage figures shown in selfcare portal and FUP top up page different? Which one should be the correct figure?
Whichever is higher usage shown is the more accurate one.
I'm not kidding :D Assuming both are accurate readings but with some delay, the one with higher usage is obviously (logically) the more accurate/recent one!
@vishalrao
Off topic: I have a MI Tv 4A Pro 49inch with, most probably, 100Mbps LAN Port. Now, what happens is, if I connect the TV to a router with 100Mbps LAN port then internet access is available on the TV. But if I connect it to a router with Gigabit port, then it says 'Ethernet not connected'. It's very irritating. Anyone with the same problem and has a solution, please share.
that's what you get for buying cheap TV :D
but seriously, you can try using a ordinary Cat4 ethernet cable which will only connect at 100 mbps even on gigabit port?
I have 3 tvs. Samsung, Sony & MI TV. Mi TV is in my kids room. Used mostly for watching youtube kids. From your answer, I know that, you didn't understand what I am asking. All the cables sre Cat 7. I think almost all tvs in the market has 100Mbps ethernet port irrespective of their price.
