BSNL Speed Hack Possible?
Lucknow
BS-ANAL 800ULD Plan
I've seen many posts on internet about hacking BSNL internet speed, I always ignore them.But is it really possible to bypass the FUP limit of BSNL?
Maybe not possible in Broadband but is it possible in recharge plans? I am having a USB with BSNL sim, If bypassing FUP is possible then I will change to USB.If that will be possible then everyone will be able to enjoy the full speed, so seems to be fake :P
Don't forget to tell the trick if possible :P
Nope, earlier their 3G had glitches. Everything has been fixed now and with unified data plans, you won't stand to gain anything.
When i had bsnl 1350 4mbps 20gb plan, i used to start a new session at 19gb, then i got 4mbps for about more 20gb with continues downloading, then the session resets automatically and i was switched to 512kbps. So i got 40gb overall on 4mbps.
