I am wondering my "line rates" are varying so much (If thats what they are). It was so less yesterday night (I guess since 1st - I felt it was slow or continued to be slow)
Line rate can't vary unless line quality becomes so poor that bsnl has to reduce sync rates in order to get you a stable sync. Are you on a 4 Mbit plan ?
3995kbps won't fetch you 4mbps. Have you complained about that ? As for the speed being 512, you need to ask them to reset your line, if doesn't get fixed on its own.
Yes... I have filed a complaint. So, Ideally how much does that need to be - which I assume they should agree to change to. So its Downstream we need to see & not Max. Att. DownstreamWell today morning seemed better. Changed from 400-ish to 3995. But they are not even setting 512/4096 . Instead of that 300 & 3995.. Do they do it on purpose?
No, they don't do it on purpose. Line rates are provisioned automatically as per the plan. Unfortunately, their system doesn't leave any room for overhead by setting the downstream sync rate at 4096kbps on a 4 mbps line. Ideally, anything above 5100kbps is good. I'd have suggested 7999kbps, but the max your line can support is 7100 odd kbps, which is also a cause of concern. Thing is, if you complain about low line rates, their favourite figure seems to be 7999kbps. I went straight from 1999kbps to 7999kbps on my then 2mbps line. However, if they set it too 7999 on your line, most prolly the connection will drop at frequent intervals. Trick is convicing them to set it around 6000kbps. Complain using the form in my signature citing that you're only getting half of the promised speed. Someone from the exchange will either call you or pay you a visit, tell him your issue, stress on the half speed. Then tell him that your line rate is low, and to accordingly adjust it
yeap. something similar happened to me. took some effort to get them to increase my speed profile. it was eventually increased from 3999 to 7999. SNR dropped down a few points. ping drops become more frequent. raw speed got better but overall performance is mediocre compared to airtel.
Even then it doesnt explain the value of 445 when I am supposed to be on "512" kbps post FUP. Anyway I have raised a complaint, lets see if I get a response & if so, when.
