My sercomm ont has s.no in the format SROTBC03xxxx@chandandutta behind your sercomm ONT there will ge GPON serial no. PUT it in new ont, it will work, workig for me,
try converting it to hex code, try both caps and small letter serial nos, idk which one works.
remove spaces from the converted code
My sercomm ont has s.no in the format SROTBC03xxxx. Is ur ont having 12 character serial number or 16 character serial number.try converting it to hex code, try both caps and small letter serial nos, idk which one works.
remove spaces from the converted code btw
Hi, Please check the OLT vendor code format (ASCII or HEX) if it ASCII i.e Char format then convert the HEX to ASCII and then try again.Just requesting some help with changing serial number for the device TP-Link XZ2000-G3. It has a validation for 16 digit hex serial. Any help to get over this validation would be appreciated.
Hey @JB701, can you provide the script on gist or something? I recently bought the TP-Link XZ000-G3, changed my PON SN to the one in ZTE, and PON is in a "Registered (O5)" state but I'm facing a similar issue of no PADO response to PPPoE PADI beacons.Ok so i created a script for scanning all the vlans from 1 to 4092 for pppoe servers, it works on the pppoe server I created for testing inside a vlan, the pppoe server shows up when connected to ZTE router. I've no clue what is going on.
