Creating a Dialer? help!!
  • Thread starter Thread starter sachins
  • Replies Replies 3
  • Views Views 2,410
sachins
The Bastard Son
Thane
Cablenet
so i received the modem router whatever three days ago. it's type 2 and the make of the modem is "dna a211-i". it has four lan jacks and a wifi. the people who installed had no idea what they were doing. they connected the lan jack to the pc. the telephone wire and the power adapter to the router. they said the router was pre-configured. they themselves had no idea what that meant. next they proceeded to make a dialer and as soon as they switched on the modem, a "caution" sign would appear over the "two computer" icon thing in the taskbar. after almost an hour we were finally able to open some pages on the IE browser. the "caution" thing kept bugging saying "limited or no connectivity". according to telephone people, it was an exchange problem and that they had had been experiencing it since a few days. they left and the next thing i did was switch off the computer and inspect the modem and there was a "reset" thing at the back which i pressed for a few seconds until the lights did a disco and the modem switched off. switched it back on and went to configuration at 192.186.1.1 and pre-configured the modem to use the username and password at there itself. now i want to use a scheduler script which requires a dialer to dial the number and disconnect at the right time. i think if i remove the username and password from the modem configuration menu then i can create a working dialer but im worried about the caution thing "bugging" me again. can somebody here tell me the steps to follow right after "resetting" the modem. creating a dialer and security, that sort of thing.
thank you essbebe. didn't realize it was that easy. the dialer thing works now. are you sure the imran helper thing isn't a trojan or if it's sending out any confidential info?
