essbebe,
I did create an Id at the registration link you provided, but no show on the final \"check usage\" page. Seems like I really do need a new BSNL account to be able to work this.
So - any volunteers? Can anybody share their credentials with me so I can update DataFox? I am planning a refresh in the next month or so and adding support for this new site is really important!
Thanks!
Brian.
Brian, I can give the credentials, but that's not going to help, as the portal id works only from the new ip address range. I have both connections and have tested it. The only option for testing without taking a new connection would be to set up a proxy server and get the credentials.
Also I feel the new portal is going to change as its worse than the previous one in many respects. I have already found the following limitations when compared to the old one
1. You don't know anything about your plan, which plan when it was activated etc.
2.Consolidated Unbilled Usage shows an amount which is ambiguous
3.Having a long portal id makes life difficult for usage check.
4.Having one page with all connection details is even more difficult.
Sunish
Dataone Quick Usage Finder
