Sunish I can confirm this, it happens to me too.
I called BSNL official and have received the 14 digit portal ID from BSNL. I get IP of 117.x.y.z.
That p3hosting page loads only with IE-tabs in Firefox, and after login I get blank screen.
How can one check usage then? I am feeling very helpless, since I have been trying for long time (see past posts/threads). There is no hope for me it seems. Even Datafox gives login error.
Sorry for the delay. But I found my stupidity (my portal id which was saved in FF was correct, but what I entered in Opera and IE was wrong)and was busy working with the new version of DQUF. So here are my findings..
1) The new portal works with Opera,FF and IE without problems.
2) The IP range to access the portal is not restricted, you can access it from any ip address.
3) Looks like the portal is under testing and there are two different versions, whose screen outputs are different. The screen shots I saw in some posting on these forums is different from what I get. I get a screen with no date range selection or search function. The probable reason could be its not one month since I got the connection.
4)There is no message for incorrect password/username combination. The portal just displays a blank page.
5) The blank page can also result when the portal is down or could not fetch usage records.
6) The portal is down most of the time and at times shows zero records fetched with zero usage, which might change all of a sudden to actual usage.
7) There's a considerable delay in updating the records, which can be as high as two days.
[If somebody is interested in beta testing the new version of
DQUF with limited support for the new portal, please send in an email request. I would appreciate request from users who are knowledgeable enough to figure out differences between program problems and use problems and those who have a flare for finding faults
Sunish
