Hey Sunish,Thanks for the clarification. On the thread essbebe posted above, vipin.r says he can check usage details even from his Sify connection. Any ideas what is going on here?Brian.
Brian.
I'm not sure what happened, but now even I can check the new portal when my ip is in the 59.xx.xx.xx series. If you need the username and password, I can give it to you. Its' plan 250, but one month is not over yet. So I can't get the billed usage. Also the usage doesn't get reflected on the portal as fast as the old system. sometimes it takes more than 2 days.I would also appreciate if someone can give me the username and password for other plans than Plan 250. Looks like its not possible to identify the plan from the portal.
just a little suggestion. the name is visible on the left column and you can place your blog link in the signature field. we really hate it when people tend to put their names and blog links in each and every post.
@sunish you will get blank page if your PortalID and password are incorrect. Opens in IE.a 14 digit portal ID to be obtained from your Exchange.No need to register online.I need not check, in that portal because I am on IP 59.92.68.227 now.
@kang : If you are a new user for BSNL Broadband , obtain a 14Digit Portal ID from your Exchange with password as password.. Then check your usage at ( for Ip 117.xx.xx.xx) http://p3hosting.bsnl.in:9080/BroadBandCustomerPortal/
Datafox will work very nicely for IP 59.xx.xx.xx and with FireFox browser.
I called BSNL official and have received the 14 digit portal ID from BSNL. I get IP of 117.x.y.z.
That p3hosting page loads only with IE-tabs in Firefox, and after login I get blank screen.
How can one check usage then? I am feeling very helpless, since I have been trying for long time (see past posts/threads). There is no hope for me it seems. Even Datafox gives login error.
