@ravindra.g.rao
Welcome toBroadbandforum.in
It will work with FireFox browser only.
And if you are a new user BSNL BB , none of the usage meters will work. ( being modified)
Obtain a 14 digit portal ID and password from your Exchange and try here.
http://p3hosting.bsnl.in:9080/BroadBandCustomerPortal/
Use this in your computer.
Tautology Bandwidth Meter - Internet Traffic Usage Monitor
see screen shot. You can use the timer. for 0800 to 0200 usage check.
Switch off modem at 0155 and at 0755. Start d/l around 0205 to be on safe side.
http://www.bagthatpic.com/images/0071/KcH97655.jpg
brother I am new to forum, tried to access the DATAFOX WEBSITE, BUT the link seems to be failure.any help????????????????thanks in advancechhoton
@chhoton
Website opens Ok. Yesterday there was some problem
for internet connections, due to some submarine cable problem/s.
DataFox - A BSNL DataOne & MTNL TriBand bandwidth usage monitor
Para two:
Presume you are a new user BSNL BB ,with p 117.xx xx.xx
Use this in your computer. ( if you are on Home500 tariff plan )
Para three : If you want to help the programmer to make it work for new BSNL users, please reply. If you are an old user with IP 59.xx.xx.xx please ignore Para two.
@Dhanjal
Tautology is not for Vista
Try any program , then reach a conclusion.
If you are a new user with IP 117.xx.xx.xx DataFox will not work in Firefox.
@dhanjalsearch my 1866 posts so far for the answer ! Whether Tautology will work with Vista , or not !!
Tautology is not for Vista, i will apply for a new connection on Monday, How can i check my internet usage. Is Datafox enough, there is also an application from sourceforge. Isn't that good ?
http://duf.sourceforge.net/
Hi Dhanjal
Tautology Bandwidth Meter would surely work in Windows Vista,
Most applications that worked in Windows XP would work in Windows Vista.
But the application's user interface seems outdated.
You can try Netmeter instead,
available from NetMeter 1.1.3 (stable) released .
