ashishgoel
Don
My stats - Downstream Upstream SNR Margin : 44.0 6.0 db Line Attenuation : 23.0 13.0 db Data Rate : 2048 1088 kbps i think my repeated emails to GmBB and 1504 has worked finally, though it has taken lot of time....ab ek naya panga ho gaya hai.... earlier my upstream was 256kbps (with 2 MBPS down), and the connection was stable even with two joints in between and along ( as i don't have a splitter), and i was gettin SNR as 27 (downstream), and use to increase to 44 whenever i lift the handset, while SNR UPstream use to be steady at 11.since yesterday, my link wasn't stable ( so i switched to my other u/l connection). before complainin to 1504, i tried to search the problem, and this what i discovered - my upstream was increased to 1088kbps ( sometime 1192kbps). But for this i've to remove all joints to get a stable link (i.e. direct connection - no calling) otherwise the adsl light just blinks n blinks n blinks, and also my SNR margin Upstream has been reduced to 6 (from 11).i'm able to get a stable connection with my joints and no splitter with Airtel 220 BX router but one phone has to be switched on (as it increases the SNR margin value hence again no calling) but not with my billion router....what i concluded that, with the joints and increased upstream speed, my original router (billion company) isn't able to get a stable connection probably because of poor SNR margin of upstream.I borrowed a splitter from my freind [ beetel ( airtel )], but there was no effect or improvement....i'm thinkin to send another request to GmBB and 1504 to downgrade my Upstream to max 512 kbps or should i wait n watch for sometime... what do you all suggest??
