A.TCP/IP settings advanced Check TCP/Ipfiltering settings
B. Modem settings : ( A & B & C as suggested by Vishalrao)
C.( about router /modem internal settings later if needed. )
1. Go to Start/Settings/Control Panel and open
Modems.
2. Click Properties and click the Connection tab.
3. Click Port Settings and bring the Receive Buffer
slider down a notch.
4. Hit OK and try your download again.
5. Once your file has been successfully received,
you can go back in and increase the buffer settings
back to where they were.
D:
The temporary internet file cache is too small to
contain the file as it downloads.
* Enlarge the temporary internet file cache: In
Internet Explorer go to Tools > Internet Options >
General tab > Temporary Internet Files > Settings,
and increase the Amount Of Disk Space To Use
setting to 150 MB. (The default is 50 MB.)
( probably too much Temp IE files/ History etc : Clear every day )
ccleaner from filehippo.com - Download Free Software : Daily before going to bed !
Modems.
D:
