Facing regular Disconnection while using Bridge mode!
  • Thread starter Thread starter Dravin
  • Replies Replies 11
  • Views Views 1,801
@Lolita_Magnum Actually I am able to access both router Airtel and TP-Link router. Dont know what happened. My Connection is ZTE Airtel -> TP-Link -> PC. Still able to access Airtel ZTE router Login page.
These ONTs do not shut off routing even in bridge which is a bit surprising. I have same ZTE and I can access both even when in bridge.
Hence I always comment that when in bridge disable all WAN dependent features on ONT else they take precedence e.g. firewall or port forwarding etc
Code:
2022-10-29 04:13:32 icmpv6[8801]: <6> 267052 send advertisement(RA) with prefix <null> and mtu <null>
2022-10-29 04:13:32 icmpv6[8801]: <6> 267051 receive solicit(RS) from dc:28:d4:3f:2a:85
2022-10-29 04:13:29 dhcp6s[8828]: <6> 266052 send advertise with ipv6 <null> and dns 2606:4700:4700::1111 2606:4700:4700::1001
2022-10-29 04:13:29 dhcp6s[8828]: <6> 266051 receive solicit from dc:28:d4:3f:2a:85  with DUID 00:01:00:01:2a:d2:3e:95:1c:1b:0d:a4:26:f0 and IAID 61c1b0d
2022-10-29 04:13:29 network[0]: <6> 290000 lan port link up
2022-10-29 04:13:27 network[0]: <6> 290000 lan port link down
2022-10-29 04:10:58 icmpv6[8801]: <6> 267052 send advertisement(RA) with prefix <null> and mtu <null>
2022-10-29 04:10:58 icmpv6[8801]: <6> 267051 receive solicit(RS) from fe80::c8e6:43ff:fe50:38c3
2022-10-29 04:10:57 wireless[3453]: <6> 208054 ath0:STA  IEEE 802.1X succeeded to athorize
2022-10-29 04:10:57 wireless[3453]: <6> 208052 ath0:STA  IEEE 802.11 associated
2022-10-29 04:10:57 wireless[3453]: <6> 208051 ath0:STA  IEEE 802.11 authenticated
2022-10-29 03:49:29 network[0]: <6> 290000 lan port link up
2022-10-29 03:49:27 network[0]: <6> 290000 lan port link down
@Dravin I have a question. When you put the ONT on the bridge, Do you use VLAN in the TP-Link router? If yes, then that is the issue. TP-link router might disconnect in case of VLAN due to ARP cache. Try to configure the VLAN on ONT before bridging the port. Or find a way to clear the ARP cache frequently.
