Fax Problem Over Wifi Network
  • Thread starter Thread starter arihantddn
  • Replies Replies 3
  • Views Views 2,748
arihantddn
BSNL
Hey buddiesI just bought a HP Officejet Pro 6500 all in one ethernet printer today. I just connected it to ethernet port on my router & ran the cd provided over my desktop and laptop and set up was easy to done. It is able to print/ scan/ copy and fax using my desktop. But while on my laptop (wifi) it is not able to send fax, while it is printing/ scanning and copying.Every time i try to fax using my laptop it shows an error 'scanner was unavailable, retry fax'. Infact scanner is available n workin fine. Please help..Thanx n regards
u need to setup the fax number in the Printer ... i too got the same printer in my friends office ... . .See that only the top one might act as the Fax ....
How to set up the fax number in the printer, i suppose it asked for my number when i was installing the software & thats there in its memory.
Cudnt get u 'See that only the top one might act as the Fax ', plz explain.
rgds
See the HP solution center software ........... U will see the Settings options in it..... Right Bottom ...then upon opening it u will see all the options scan copier and fax.... fill all the fax options in it ...
