Fedora ADSL Connection Problem
  • Thread starter Thread starter bheemarjun
  • Replies Replies 36
  • Views Views 12,077
Hi folks,I have been wringing my hair out and digging around with truss all this week, but not been able to figure out why I get the error message as "kernel NETDEV WATCHDOG eth0 timeout" whenever I boot and openup "dmesg". I am using a PIII (Coppermine) with a USB MT882 modem which works fine under XP. I have tried Fedora core version 5, 3 and even Redhat ES relaease 4, RH 7.3, and even tried rebuilding kernel 2.6, 2.4 with options to include ppp and exclude apic. I have tried to use rp-pppoe3.8, but have found no success in even pinging 192.168.1.1, let alone getting connected to internet. I do not have a ethernet card and want to use the USB (CDCEthernet mode) only. Somewhere I remember to have read, interrupt to these USB devices are either level sensitive or edge sensitive. Is this some hardware prob that my PC can not drive the modem? Can someone help me?Thanks in advance-krishnacgh
QUOTE(krishnacgh @ Oct 12 2006, 07:39 PM) [snapback]65040[/snapback]
Hi folks,
Thanks in advance
-krishnacgh
[/b]
paste the output of dmesg and lsusb.
Are you sure eth0 instance of your USB interface is properly configured ?
/IMHO get one NIC card and use it./
QUOTE(vichitra @ Oct 12 2006, 07:48 PM) [snapback]65042[/snapback]
[/b]
The relevant outputs are:
eth0 Link encap:Ethernet HWaddr 00:0F:A3:8E:2D:88
inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::20f:a3ff:fe8e:2d88/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:312 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:126 (126.0 b)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1874 errors:0 dropped:0 overruns:0 frame:0
TX packets:1874 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2584070 (2.4 MiB) TX bytes:2584070 (2.4 MiB)
netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
lsusb gives
Bus 001 Device 004: ID 05fe:2001 Chic Technology Corp.
Bus 001 Device 003: ID 1110:5c01 Analog Devices Canada, Ltd (Allied Telesyn)
Bus 001 Device 002: ID 058f:9254 Alcor Micro Corp. Hub
Bus 001 Device 001: ID 0000:0000
lspci -vv -xx gives
00:00.0 Host bridge: Intel Corp. 82810E DC-133 GMCH [Graphics Memory Controller Hub] (rev 03)
Subsystem: Intel Corp. 82810E DC-133 GMCH [Graphics Memory Controller Hub]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Status: Cap- 66Mhz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort-
QUOTE(krishnacgh @ Oct 12 2006, 10:57 PM) [snapback]65089[/snapback]
RX bytes:0 (0.0 B) TX bytes:126 (126.0 B)
[/b]
hmm .. that 312 errors signal a serious problem with your networking. I have never used USB with adsl modem. Actually, use of USB connection is strongly discouraged. To be quite honest, the best option would be to go the LAN card connection route.
Here are a few questions that come to mind:
1. Are you sure your USB connection to the ADSL modem is seen as eth0 by your Linux machine?
2. What is your configuration of your eth0? (see /etc/sysconfig/network-scripts/ifcfg-eth0 file)
3. Could you post the output of "lsmod", "usbmodules" and "lsusb" commands.
Other than that, please take a look at these few lines:
http://www.faqs.org/docs/Linux-HOWTO/DSL-HOWTO.html#AEN420
dmesg contains
NETDEV WATCHDOG: eth0: transmit timed out
eth0: no IPv6 routers present
parport0: PC-style at 0x378 [PCSPP,TRISTATE]
Thanks
-krishnacgh
[/b]
please post complete output of /dmesg/.
QUOTE(vichitra @ Oct 13 2006, 10:48 AM) [snapback]65136[/snapback]
[/b]
______________________________
Complete output of dmesg is
Linux version 2.6.9-1.667 (bhcompile@tweety.build.redhat.com) (gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) #1 Tue Nov 2 14:41:25 EST 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000017ef0000 (usable)
BIOS-e820: 0000000017ef0000 - 0000000017ef8000 (ACPI data)
BIOS-e820: 0000000017ef8000 - 0000000017f00000 (ACPI NVS)
BIOS-e820: 0000000017f00000 - 0000000018000000 (reserved)
0MB HIGHMEM available.
382MB LOWMEM available.
zapping low mappings.
On node 0 totalpages: 98032
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 93936 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 AMI ) @ 0x000fc060
ACPI: RSDT (v001 AMIINT AMIINT10 0x00001000 MSFT 0x0100000b) @ 0x17ef0000
ACPI: FADT (v001 AMIINT AMIINT10 0x00001000 MSFT 0x0100000b) @ 0x17ef0030
ACPI: DSDT (v001 INTEL WHITNEY 0x00001000 MSFT 0x0100000a) @ 0x00000000
ACPI: BIOS age (1997) fails cutoff (2001), acpi=force is required to enable ACPI
ACPI: Disabling ACPI support
Built 1 zonelists
Kernel command line: ro root=/dev/VolGroup00/LogVol00 rhgb quiet
mapped 4G/4G trampoline to ffff4000.
Initializing CPU#0
CPU 0 irqstacks, hard=023d5000 soft=023d4000
PID hash table entries: 2048 (order: 11, 32768 bytes)
Detected 1002.535 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 383816k/392128k available (2068k kernel code, 7696k reserved, 647k data, 144k init, 0k highmem)
Calibrating delay loop... 1982.46 BogoMIPS (lpj=991232)
Security Scaffold v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
There is already a security framework initialized, register_security failed.
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium III (Coppermine) stepping 0a
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
checking if image is initramfs... it is
Freeing initrd memory: 947k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfdb91, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040816
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 © Adam Belay
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Transparent bridge - 0000:00:1e.0
PCI: Using IRQ router PIIX/ICH [8086/2410] at 0000:00:1f.0
PCI: IRQ 0 for device 0000:00:1f.3 doesn't match PIRQ mask - try pci=usepirqmask
PCI: Found IRQ 3 for device 0000:00:1f.3
PCI: Sharing IRQ 3 with 0000:00:1f.5
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
audit: initializing Netlink socket (disabled)
audit(1160794597.962:0): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key 6ECDA687281A73E5
- User ID: Red Hat, Inc. (Kernel Module GPG key)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
vesafb: probe of vesafb0 failed with error -6
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.100 © Dave Jones
agpgart: Detected an Intel i810 E Chipset.
agpgart: Maximum main memory to use for agp memory: 320M
agpgart: AGP aperture is 64M @ 0xe8000000
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
divert: not allocating divert_blk for non-ethernet device lo
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH: IDE controller at PCI slot 0000:00:1f.1
ICH: chipset revision 2
ICH: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0...
hda: ST340810A, ATA DISK drive
hdb: CRD-8483B, ATAPI CD/DVD-ROM drive
Using cfq io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: HL-DT-ST GCE-8527B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
ide2: Wait for ready failed before probe !
Probing IDE interface ide3...
ide3: Wait for ready failed before probe !
Probing IDE interface ide4...
ide4: Wait for ready failed before probe !
Probing IDE interface ide5...
ide5: Wait for ready failed before probe !
hda: max request size: 128KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 hda10 hda11 > hda3
hdb: ATAPI 48X CD-ROM drive, 128kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
hdc: ATAPI 52X CD-ROM CD-R/RW drive, 1536kB Cache, UDMA(33)
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 1024 buckets, 32Kbytes
TCP: Hash tables configured (established 32768 bind 9362)
Initializing IPsec netlink socket
NET: Registered protocol family 17
Freeing unused kernel memory: 144k freed
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
cdrom: open failed.
cdrom: open failed.
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
ext3_orphan_cleanup: deleting unreferenced inode 82782
EXT3-fs: dm-0: 24 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
inserting floppy driver for 2.6.9-1.667
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
PCI: Found IRQ 3 for device 0000:00:1f.5
PCI: Sharing IRQ 3 with 0000:00:1f.3
PCI: Setting latency timer of device 0000:00:1f.5 to 64
intel8x0_measure_ac97_clock: measured 49463 usecs
intel8x0: clocking to 48000
USB Universal Host Controller Interface driver v2.2
PCI: Found IRQ 11 for device 0000:00:1f.2
uhci_hcd 0000:00:1f.2: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1f.2 to 64
uhci_hcd 0000:00:1f.2: irq 11, io base 0000d400
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
usb 1-1: new full speed USB device using address 2
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-2: new full speed USB device using address 3
usb 1-2: configuration #2 chosen from 2 choices
usb 1-1.4: new low speed USB device using address 4
input: USB HID v1.00 Keyboard [Device USB Device] on usb-0000:00:1f.2-1.4
input: USB HID v1.00 Mouse [Device USB Device] on usb-0000:00:1f.2-1.4
divert: allocating divert_blk for eth0
eth0: register usbnet at usb-0000:00:1f.2-2, CDC Ethernet Device
usbcore: registered new driver usbnet
EXT3 FS on dm-0, internal journal
cdrom: open failed.
cdrom: open failed.
EXT3 FS on hda3, internal journal
EXT3 FS on hda10, internal journal
EXT3 FS on hda7, internal journal
EXT3 FS on hda9, internal journal
NET: Registered protocol family 10
Disabled Privacy Extensions on device 02369a00(lo)
IPv6 over IPv4 tunneling driver
divert: not allocating divert_blk for non-ethernet device sit0
drivers/usb/input/hid-input.c: event field not found
Adding 787144k swap on /dev/hda8. Priority:-1 extents:1
ip_tables: © 2000-2002 Netfilter core team
lp0: using parport0 (polling).
lp0: console ready
lsmod gives
Module Size Used by
parport_pc 24705 1
lp 11565 0
parport 41737 2 parport_pc,lp
autofs4 24005 0
sunrpc 160421 1
md5 4033 1
ipv6 232577 8
usbnet 26441 0
mii 4673 1 usbnet
joydev 8705 0
uhci_hcd 31449 0
snd_intel8x0 34829 2
snd_ac97_codec 64401 1 snd_intel8x0
snd_pcm_oss 47609 0
snd_mixer_oss 17217 2 snd_pcm_oss
snd_pcm 97993 2 snd_intel8x0,snd_pcm_oss
snd_timer 29765 1 snd_pcm
snd_page_alloc 9673 2 snd_intel8x0,snd_pcm
gameport 4801 1 snd_intel8x0
snd_mpu401_uart 8769 1 snd_intel8x0
snd_rawmidi 26725 1 snd_mpu401_uart
snd_seq_device 8137 1 snd_rawmidi
snd 54053 11 snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 9889 2 snd
floppy 58609 0
dm_snapshot 17029 0
dm_zero 2369 0
dm_mirror 23341 2
ext3 116809 5
jbd 74969 1 ext3
dm_mod 54741 5 dm_snapshot,dm_zero,dm_mirror
lsusb gives
ifconfig -a gives
DEVICE=eth0
ONBOOT=yes
BOOTPROTO=none
IPADDR=192.168.1.3
NETMASK=255.255.255.0
GATEWAY=192.168.1.1
usb modem seems to be correctly configured as eth0, for, if modem connection
is removed, sys says eth0 is not connected.
Thanks
-krishnacgh
QUOTE(vichitra @ Oct 7 2006, 07:10 PM) [snapback]64431[/snapback]
RTL8139 has native driver in kernel.org repo, try 8139too or 8139cp.
Beware intex and some other vendors sell totally different chipset based card
as RTL8139 based one, but in real underlying chipset is different.
Stick to ETHERNET based solution
Strange FC4 does have driver for RTL8139 based ETHERNET card, I suspect you having a card that been sold as RTL8138 based but having completely different chipset.
Could you please paste the output of command
lspci -vv -xx
You have to be root to execute above command.
[/b]
Hi Vichitra,
Sorry for the delay it took me few days to download and install FC5.
Installed FC5. It didn't help in anyways.
Yeah I think that one is some fake realtek card, The box says "Advik" and one slip was inside for realtek 8139.
Here is the Ethernet Controller part of output for "lspci -vv -xx"
Ethernet controller: Unknown device 1904:8139 (rev 01)
Control: I/O+ Mem+ Busmaster+ SpecCycle- MemWINV- VGASnoop- PatErr- Stepping- SERR- FastB2B-
Status: Cap+ 66Mhz- UDF- FastB2B+ PatErr- DEVSEL=medium >TAbort- means the command prompt)
$> ifconfig -a
You may need to be root to run this though. Or try "/sbin/ifconfig" instead of just "ifconfig".
The realtex 8139 driver is so common that I find it very strange that your card runs with this driver and FC was not able to recognize it. The above two commands will clarify many things and we can start debugging from there.
Finally, I think you can open a GUI window to control your networking settings (after your card detection works). You should look for System->Networking in the main menu on your desktop. OR, you can run this gui from the command line using the following command:
$> network-admin
You will need root password to actually use this gui.
GL.
[/b]
Hi,
For the command "ifconfig -a", i get the following interfaces: "lo" and "sit0"
lo LINK ENCAP: lOCAL lOOPBACK
RX packets:1749 errors:0 dropped:0 overruns:0 frame:0
RX packets:1749 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2425588 (2.3 MiB) TX bytes:2425588 (2.3 MiB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
If I run ifconfig without any option "ifconfig", I get only "lo".
Thanks,
Raffi
Hi Vichitra, bsnluser,
Please advise me, I am trying to setup Linux for almost 10 days :(
If I need to buy a new Ethernet card, Please advise me the brand so that I'll not have any problem with fedora Core 5. I am thinking of taking my box when I go to the shop to purchase the Ethernet card, But I doubht whether that guy will agree to plug in the card, test in Linux, and then sell....
Thanks,
Raffi
QUOTE(raffimd @ Oct 14 2006, 06:43 AM) [snapback]65271[/snapback]
Hi Vichitra,
[/b]
Isn't FC5 cool? Nice distribution. Lets see if we can have this little LAN trouble of yours solved.
Thanks,
Raffi
[/b]
Here are a few things to try:
1. If you open the "Neworking" gui (from System menu perhaps), does it list your LAN card? You can try opening the gui by using "network-admin" command also (on a terminal).
2. What are the contents of your /etc/sysconfig/network-scripts/ifcfg-eth0 file? Or of "ifcfg-eth1" or ifcfg-eth2" etc.
3. What is the output of "lsmod" command?
4. What happens if you give the following command as root: "ifup eth0"?
regards.
QUOTE(bsnluser @ Oct 14 2006, 11:02 AM) [snapback]65296[/snapback]
regards.
[/b]
Hi,
Yeah FC5 is cool. Unfortunately I am not able to resolve the LAN issue yet :(
IN FC5, it is Administration-> Network Menu. I opened that GUI, I could not see any entry in the hardware tab. Linux is not detecting the ethernet card automatically.
In the Hardware Tab, I added an entry manually by selecting the respective driver (RTL8139too) and
In the Devices Tab, I added a device "eth0" for that hardware.
I could not activate the device eth0 :(
Thanks,
Raffi
Hi Vichitra,
Yeah I think that one is some fake realtek card, The box says \"Advik\" and one slip was inside for realtek 8139.
Here is the Ethernet Controller part of output for \"lspci -vv -xx\"
