Thanks for reply.. In my area bsnl underground line was installed about 7-8 years ago.vinay sam said:Hi Sujit.m,
The 1st month bill will near upto ₹2000, don't panic on seeing it. It is just because you are installing newly. ₹2000 on 1st bill is due to that they don't charge anything while installing. Everything including your landline handset, modem & service charges comes on the billing alone. So, you don't need to pay the line man installing in your home (tipping him depends upon your wish). From the 2nd month you will get regular billing (Increase in bill amount always depends on your call and day time broadband usage limit exceeding). You can also cancel the landline while you order for connection if you wish. But if you use it, you can avail 250 free local calls within bsnl network (other network call charges apply).
Hope you are satisfied with the reply...
Because no one has bsnl connection here now. Does it need to change ?
