harishsangwan
@harishsangwan :
Did you try the setup as given by me
(originally advised/insisted by the ISP)?
Was there an Improvement ?
i had that setup from before but what i tried to explain was that i have more that one wire going out from the main telephone line,parallel connection if you know what it means
Mode ADSL2
Details ..............download stream .................upload stream
SNR margin db ...........6.0 ..........................15.4
Attenuation db ..........15.0 ...........................5.9
Attainable rate Kbps ..7597 ........................1231
Rate Kbps .................6425 ...........................861
Mine is the DataOne Home500 plan-256kbps to 2Mbps
and if i am right then the above values keep changing
Mode ADSL2
