i want to buy wireless internet of BSNLplz explain bit about it,,,and also give me price of modemCan i have HOME PLANS FOR wireless internet ?if ya ! then i m already having BSNL net at my home and i want wireless modem for my laptop and will i be able to use 1 internet in both modem ?
, if you have a landline based BB connection no need
if present modem is on rent exchangeit for a wifi router
Cost Rs 1800/=plus taxes or rentat Rs 80 P.M
YES
ONE adslmodem/4lanport/wifrouter will do.
You cannot use more than one modem. Two types of wifi bsnl modems are available. One is ADSL WiFi-2 (Rs.1800/-) and another is ADSL-WiFi-TA (Rs.2250/-). You can check more details here.
You choose between BSNL 3G data card, BSNL EVDO and wired internet by BSNL. Of which I feel wired net is most economical. You can get a wifi modem from BSNL for Rs. 1,800 using which you can connect your desktop and laptop at the same time.
