Help me fix my problem
  • Thread starter Thread starter damnthenet
  • Replies Replies 8
  • Views Views 1,415
damnthenet
Dataone
HiI am a dataone user and got my connection last month......I have a funny problem (I mean it may sound so for a few)....I am able to connect to internet in the night hours ( ater eve 6 pm). But if I try in the afternoons, I am not able to connect.I called the local bsnl guys but very bad response.Can any one tell me what kind of problem it might be????Thanks
Welcome to Broadband.inCan you use the phone in the afternoons ? Check condition of your connection in Diagnostics mode. in the modem. Or connection period has been set in your computer/modem . See scheduled tasks in computer.Mention modem model to check.
check your usage, is there any entry for afternoon session. If you are in areas where Port Binding is not activated (in my area too), and someone has your username and password, he will connect internet using your user/pass, then you will not be able to connect for that period.
Thanks for the reply.I take total control of my pc and so no quesion of scheduled task (I also checked out)At afternoons, i am able to use phone but it is noisy at times. When I connect to internet in afternoons, I get GOOGLE sometimes which is the startup page and then the lights go out and start one by one again and then they go off in a cycle and I cannot get connected. I do not know how to do the diognastics process. please tell me. As for as my NETWROK CONNECTIONS are concerned, I have not been given any specific Ip address and all, they are set to obtain all info automatically.And my modem model is UT300R2U got from BSNL itself.I got the portal page now and saw usage for last month............No info to see for this month (no info regarding JAN in billed usage)My plan is "500C"
Best thing is to call 1500 and file a complaint regarding noisy line. I do have the same problem in bangalore since my line is from normal box. Dont worry about IP address since those are assigned automatically. Make sure you call up the local exchange people and tell the problem to them (Hope they know about broadband and internet) !!! Hope they have fixed a Splitter to seperate Data and Voice !! Regardsappus
@damnthenet
No problem.
Open IE type 192.168.1.1 Id admin password utstar
modem programming page will open.
Select ADSL status ( if you dont see this try 192.168.1.1/main.html
Just report SNR and attenuation figures.
See for reference screenshot acceptable Huawei( left) SNR should be high (>10)ATTN LOW
Para Two : For usage check this month's select unbilled usage.
What is the error message? If you something like password not the same as the one on the domain, just put your password in the space provided and login. This worked for me. In the beginning I was also frustrated, but suddenly this idea occurred to me and it worked.
There's no sort of error message................when I switch on the modem, the lights come up one by one (power, ethernet, dsl, internet) in the modem.....then when I open the browser and click go to any site, both DSL and INTERNET light goes off... and start blinking again..........But what's surprising is that I get connection without interruption in the nights and the speed is also so good................
