Help !! Slow Speed in PPOPE
  • Thread starter Thread starter Kalps06
  • Replies Replies 25
  • Views Views 4,578
Download the TCP/IP Optimiser program.
downloaded TCP/IP optimiser.
how do i go abt optimizing,,i mean what whanges do i make to optimize it..
run the app.,select ur conn speed on the meter,select pppoe under MTU if u r using pppoe.select optimal settings,click apply,restart comp.u will get ur speeds optimized.BTW this tcp/ip thing didnt work 4 me.
I am sorry I. could not help you, and I accept failure. Last attempt for others to help you out Post the screen shot of the PPpoe page
Here's the SS of my PPPoE page.
http://imageshack.us
Guyzz right now i.e at 10.00Am in morning I m able to connect to the tracker whereas in night I don't get connected to the tracker that;s y I don;t get the speed, this is really confusing coz I know there;s no probs with my router coz in day time PPPoE works fine but in night I m forced to delete the PPPoE connection and Connect using Bridge mode.
I think that;s the only solution to all my probs keeping in mind my demands :p
Neways still wanted to know the root coz of the prob.
Just received 1st email from the Tech Support of D-Link as follows.
From the email it seems you get slow speed when the router is in PPPoE mode, and the internet speeds up when the router is in bridge mode.
You would like to have the router configured in PPPoE mode.
Ideally the mode of the router should not affect the speed you are getting.
Kindly keep the router configured in PPPoE mode, and follow certain steps mentioned and observe the improvement in the Internet speed.
Assign a static IP address to the adapter in the subnet range of the router, with the default gateway as the router's IP address.
Verify the DNS IP addresses provided to you by your ISP and assign them to the adapter.
Try to ping the GLB router and check the reply. Try accessing internet and verify the speed.
I had already assinged static ip to my lan card and also cheked the ping and dns :(
