How to change IP in always on wifi connection
  • Thread starter Thread starter birdflu
  • Replies Replies 8
  • Views Views 3,729
birdflu
BSNL
Hi all,I have a BSNL wifi modem earlier I use to dial to connect to internet so every time I disconnected & reconnected my IP use to change (People using Filehosting services might know the importance of IP change) Now the problem is that I have installed WIFI modem which is always on mode, is there any way that I can disconnect & reconnect my WIFI modem resulting in new IP ?Or should I try bridge connection ? (But what i understand in Bridge connection I cannot only connect 1 Laptop at a time)Please advise
IF YOU HAVE A STATIC ip then it won't change
otherwise if dynamic just restart your router
Yes i have a dynamic IP
But how to restart the router ?
Do I need to manually restart it or is there some commands to do so?
just hit the restart button at te back of the router and then turn it back on
or take out the power and then pug it back in
check your IP first and then again after changing here
What's My IP Address? Networking Tools & More
Ya I know that but to do it we need to physically be near the modem is their any command that could disconnect & reconnect the net giving us a new IP
the operators can do it from their stations
from where do you want to do it from?
Ok let me explain I have a BSNL connection & my modem is located on groundfloor I am using my laptop from 1st floor So if i need to change my IP by disconnecting I have to go downstairs and manually switch-off/on the wifi modem Can i pass commands from my laptop so the modem can disconnect & reconnect
Ok let me explain
Yes, you can. You need to login to your wireless router using any compatible browser. & find reboot button.
Thanks that worked fine :)
