How to Connect TP-XZ000-G7 to Airtel Xstream Broadband?
  • Thread starter Thread starter mystic_235
  • Replies Replies 278
  • Views Views 44,671
i have used multiple local isps so there is no issue having multiple xpon as i can give it ao anyone. placed the order and texted on whatsapp to reconfirm if it is v1. if anyone can confirm if they got a different VLAN other than 100
get over @MZRecords v1 please I have confirmed and g3 v2 works perfectly, its only adding to more chaos here also try with the updated firmware it works
@Aryanraj hariselio doesnt have vlan as 100 he also had same issues
see these are vlans a person gets if its not hundred in your area
this will vary place to place but try putting 2507 once
is there any v3 version? i see isp version and v2 version only. i will recheck the vlan, will also check the vlan scanner.
@anmolbhard004
Tried vlan 2507 and it doesn't connect either on PPPoE over here.
@Aryanraj yes there is V3 version available as well. Not sure where you can buy it from. You can check the below link for V3
