How to enable Port 80/443 forwarding?
  • Thread starter Thread starter Nucleo
  • Replies Replies 6
  • Views Views 41
Delhi
Currently whenever I try to port forward 80 or 443 (HTTP/HTTPS) I get a "Rule conflict with Remote MGMT setting" Error
I cant seem to be able turn it around, and technical experts/customer service say this is a user-side issue we cant solve. and refuse to acknowledge.
How can I allow those ports? any way?
Regardless of nat, you can't do it from the stock router. You can bridge / replace the router with your own and it won't be a problem anymore.
@thatayush wdym bridge/replace? I replaced the router but it stopped working after some time and the CS team said that replace back to the Airtel router.
What is bridging and how can I do it?
Another question, will attaching another router to the Airtel router and then forwarding that work?
@Nucleo You can't directly replace the router, there's some things you have to copy/ensure in the new one, and that info can also be found in the forums (search for TP-Link xx530v in the forums for example).
Bridge means the Airtel router (or anything) basically acts as a dumb device converting between the fiber to the ethernet, "bridging" the line in a sense. There's more happening behind the scene, like the Airtel router authenticating to the OLT for one, but not required to know.
Since you're already subscribed to static IP, call them up and ask to setup bridge mode where the Airtel router will permanently become a dumb bridge.
Then you can attach the next router and forwarding that will work, but depends on if the next router you have allows it or not.
