I have 200Mbps internet plan. I am using Syrotech's SY-GPON-2010-WADONT. I am getting 200Mbps speed on 5Ghz.
My problem is with two LAN ports which is providing less than 100Mbps. In its datasheet, it says the ethernet interfaces are auto adaptive 10/100/1000 ethernet interfaces.
I don't know what's wrong. I can't see any settings related to them in router page.
I have two connections to LAN ports, one from Smart TV & other is CCTV. In router info page, one port is 100M & another(CCTV) is showing 1000M. But when I am speed testing on those ports, I'm getting only less than 100Mbps.
How to achieve full 200Mbps speed on atleast one LAN port?
Kindly help
Thank you
Kindly help
Thank you
