Got my STB today, tried to install jio tv apk but it seems like the box is locked or whatever i am not able to enable the "unknown sources" thing in the settings.
When you reset the STB , doesn't it go back to older version Android or just user data gets deleted ?
If it's the former then old Android might try to auto update through wifi so asked to switch off router. If it's the latter then we gotta figure out another way.
@bigman91 i did the reset again but didn’t connect stb to Internet, and found out that stb didn’t get back to older version. Still there’s no app installer!
You need to find out the other way
I got my connection last week and don't have option to enable apps from unknown sources.
The option is greyed out.
Is there any other option to install apps on the STB? I have IP STB MCM300
