how to use tikona for IP camera??
dhruvpandit
TATA DOCOMO 3G, GTPL (local ISP)
i am planning to have a wifi IP camera for my workshop. but problem is that, i dont have any PC in workshop. so , how i can get my camera online always with some wifi-router or so???
First, you need IP for IP camera. I mean static ip. Actually, tikona allows users to connect them through dynamic IP at every login and log out or after sometime, it generate new ip for each users. If you do not want to buy a static ip, you have to use computer to set up.
Once you have this, then you should have this kind of system.
2 Camera Zeus Mk2 Lite 500GB CCTV Kit without Monitor CCTV Kits, 2 Camera 250GB ZEUS Mk2 CCTV Kit no Monitor [ZEUS_MK2_2_cam_CCTV_KIT_NO_Mon] - €439.00 : CCTV Ireland, Online shop - Buy all your CCTV equipment here
This system may cost you a lot because this is not an Indian company but you can discuss your requirement with this company, CCTV Camera, Fire Alarm System, PA System, Smoke Detector, CCTV India.
Apart from this,
you can buy wireless CCTV camera and config it with wifi router. This would be cheap and efficient.
Like this, How to make any CCTV Camera Wireless with Wireless Adaptor - YouTube
Apart from this,
i know ip camara is the best and cheapest and versatile, but main problem is that how i can bypass / automate tikona's login procees, coz, i dont have any PC , i just want to make it 24 hrs ON for surveillance.
Use DHCP as static ip and once you set up everything with loggin. It will remain log in until system logs you out.
Then you have to relogin.
or buy a static ip.
thats the main problem, if power cutdown happens , then the camera will be of no use :(
