IPS monitor 24 inches Best in picture quality
  • Thread starter Thread starter Deleted member 13033
  • Replies Replies 17
  • Views Views 2,629
D
Hi my aoc monitor serving me well for last 7 years stopped working after i decided to repair it my self, when my maid used colin on it and a blue vertical line came on it. The aoc-i2353ph specs are 50million dynamic ratio, 75hz digital refresh rate.
I need a better option or atleast same. I got LG 24MK600M, but it suffering from black light bleed at bottom and has sort of yellow/grey tint i dont feel its that much worth paying 10k for it..
Budget under 15k preferred.
ya maybe, not keen on it though..i want very good color, for movies pics, and good text readability. I should be able to title monitor back or forth if not up or down atleast.
budget 2k/4k displays would not give you better picture quality. it would likely be worse. i would still suggest looking at ultrasharp series from Dell.
there are too many right now, post some links from Dell na then ? also is the benq any good 24 inch ( IPS model) has good reviews.
27 inch is costing more than 50K after GST. I guess I would have to downgrade to 25 inch myself from 30 inch.
Got the LG 4k one one. Looks good. Best part is my 6yr old HD 7770 is able to run 4k Display using display port at 60hz. Color and text and looks beautful, specially if 1080P monitor is kept right next to it, and one realizes what is missing in 1080P monitor.
However considering the price difference between 4k and 1080P anyone on budget is not really missing that much i would say. These 4k needs to come under 15k. I don't feel the current price is that much justified for 24 inch monitor.
Initially used the monitor with hdmi it scaled down to 30hz, found a ytube video and solution arrived :) to use display port to run it at full 4k with 60hz. Monitor luckily comes with Display cable, which was welcome. Otherwise not sure if i would have kept it or bought a cable for it :p
