What
router r u currently using and what are the issue faced? Is it only the wifi speed? Analyze your requirements, do you want ddns, guest network,
VPN server and so on and then make a purchase decision based on features/cost/quality.
As u wud know Wifi speed is a function of router software/channel width/ some router settings + external environment including interference
So it might change or might not. A matter of chance. Try fiddling with settings whatever possible also channel width, router placement etc and see if that makes any difference. I hear that
Asus routers are better than
TP-Link but they are quite costlier. Tplink is more budget friendly. I have good experience with
D-Link and tplink
Airtel has provided f670l which in general meets my requirements. I occasionally put my dlink in bridge but mostly use f670l. eventually I am planning to go for ax from tplink mostly in a few months time.
The initial router provided by airtel with my fiber was crap. gx brand. It did not even have basic features present. I fought with airtel for replacement for 2 weeks and then they gave me f670l. I asked for dumb
ont actually but they refused. bridge mode is way to go bcos in this fiber
business all fiber routers are designed for isps, not for end consumers. it's b2b not b2c model that they have adopted. i miss ethernet RJ45 days now!!u cud just buy any router of ur choice. at the max u needed to clone
mac nothing else
