@Nitin i took 100Mbps plan.... and i use 5 devices simultaneously. so the bandwidth is shared. at late night i have seen speed on Ps4 reaching to 20-25 otherwise most of times its between 10-15 range. though if we connect LAN the speed ranges to 40-50mbps. (shared with other devices)...
also if you have a Ps4 can you let me know on ports which were used for forwarding.
@Libu Can u try downloading without any other devices connected to the network and see if u get full speed or not?. I don't use port forwarding, I already get NAT type 2 on PS4 without any setting
