Main prob of Slow speed !
  • Thread starter Thread starter firo_z
  • Replies Replies 7
  • Views Views 1,707
firo_z
BSNL
Guys, the main prob of slow speed :
[*]There is LINE fault in ur telephone cable
[*]Your Telephone line is not parrelel
[*]You are having Major SPYWARE AND ADWARE in ur system
[*]Bad DNS servers selected
[*]Inteference in ur telephone line
[*]Virus in ur system
[*]very LOW amount of RAM less than 128
[*]Bad W@indows installation or corrupt Windows files
[/list]
These are the common problems if ur are getting major slow speeds....most of the time it will be either due to AD-WARE AND SPYWARE...
Hope this thread helps...:)
what about ISP server speed? today download speed is 122 kbpsand upload speed is 426 kbps checkthrough InternetFrog.com: Network Tools, Internet Speed Test and Website Tools
as in "Network Congestion"? Yes that can be added to the list too.
u mean the PHONE lines should not be parallel? i have 2 parallel bsnl fones... cud i have slow speed issues?
the phone line that comes to u home should directly go to modem first, then from modem it should go to phone. even if it requires more wirering. simple
