Guys,
on 2nd june, i asked MTNL to shift my connection. both new & old addresses were in the same exchg area. they finally got the voice line working on 27th june, but the DSL light does not come on. Im using a WAG200G BB Modem+
Router.
1504 says
ADSL is activated; Regular phone Linesman says all wires are properly connected. Ive tested the Phone splitter and the WAG200G seperately and they both work. :wall:
Any advice on this, Viralbug???
- vx
UPDATE:::: 18th July 1715 hrs, MTNL xchg said they did noy physically connect the DP jumper @ their switches from old addr to new addr. PROBLEM RESOLVED.
FOLLOWING for LE09:
DSL Connection
DSL Status:Connected
DSL Modulation Mode:MultiMode
DSL Path Mode:Interleaved
Downstream Rate:2044 kbps
Upstream Rate:260 kbps
Downstream Margin:31 db
Upstream Margin:16 db
Downstream Line Attenuation:22 db
Upstream Line Attenuation:19 db
Downstream Transmit Power:16777189 db
Upstream Transmit Power:19 db
PVC Connection Encapsulation:RFC 2516 PPPoE
Multiplexing:LLC
Qos:UBR
Pcr Rate:0
Scr Rate:0
Autodetect
isable
VPI:0
VCI:32
Enable:Yes
PVC Status:Up
Now i gotta see if i get lucky 2nite, and get some.
(MBps that is
