Rundshal Walyer
- Messages
- 5
- Location
- NA
Can anybody tell me, how much maximum memory size of microSD that can be accepted by this device? I plan to add 64GB - but nowhere in the site it says what is the limit.
So far my impression with the device is great! some facts
1. The memory can be made as a cloud storage - both via USB or WIFI (somewhere earlier in this forum I saw that you can access memory only through USB - that is NOT correct. There is an option via Admin control where you can swtich that). Strange thing however, is there is NO dual option - Memory is only USB available OR WIFI. But I am struggling to find out what is the limit?
2. I get complete 7.2 mbps connection. So no qualms about the speed.
3. There is no "N" band - however, this is a MIFI router to get you an internet connection - not designed to share data between devices. Hence, there is a maximum cap of 58 Mbps (maximum supported by "G" specifications) if you are transferring data between WIFI connected devices.
4. People are complaining about switching off from the "button". There is yet another way from brower. Go to Admin page and there is a "Switch Off" button. So you can remote switch off even though the device is not physically next to you. You do have to manually Switch on though!
5. Does get "Warm" during operation - make sure that slots for ventilation are clear - if you notice the slots - one is partially blocked another one if completely open. I guess this is done to make sure there is an air pressure differential to allow movement of air.
6. No SMS facility is a great disadvantage. If Micromax people are intelligent enough, they can just roll out a firmware which supports this. Otherwise this is a great product with the price option that we have - just Rs 2100
Hi,
You Have mentioned in the Point#1, as you have made the SD card as a cloud storage. Could you please guide me how you have done that, since even I have changed the Settings from USB Share to Web Share in the admin Page, I don't know where to access the SD Card files. If possibe send me the details to my mail ID pingjsk@gmail.com
Thanks.
Hi,
Thanks.
