There are auto disconnections at 10 pm and 8 am. Why do I need them?
use reconnect.
else if using mdma with a dialup connection, setup a windows task to reconnect at 8am and 10 pm or better, if u are on unlimited, set it to redial the connection every min under a hidden mode so even if it disconnects, will autoreconnect within 1 min. 24 hrs a day.
finally 3G working again(Sanchar haat solved the problem in straight 20 minutes) but the speed is around 1-1.5 mbps.:nono: and i have already used >200 gb so its definitely not 200 gb for 6 months .
^ so 200GB limit is not there is good news. I am facing same problem regarding speed.Speeds are highly variable some times I got 2.8 Mbps in peak hrs and some times got only 1mbps even at 2:00 am. Signal strength almost remain constant all the time some time, don't know what is the issue
all speed tests are showing diffrent results https://www.speedtest.net https://www.speedtest.net https://www.speedtest.net
