MTNL Mumbai: Rs. 999 for Unlimited Data (3 Months Promotional Plan)
  • Replies Replies 196
  • Views Views 38,650
If your ultimate need is connecting to a laptop, then buy a wifi enabled dongle, and download reconnect software. I bought mtnl 3g sim. I am using reconnect. After connecting via dongle software, just open reconnect and you are done. The software automatically reconnects just after fraction of seconds of disconnection. You won't even come to know about disconnection. This might not work well on IDM downloads. You don't have to look for any speed or disconnection issues after downloading the software. But, I'd suggest buying wifi dongle first. Downloaded 20 GBs in 4 days. Torrent speed is about 180-185 KBps avg.
Thanks varun120. I'm happy with the current setup as I am tethering on mobile and catering to multiple devices over wi-fi.
A 64GB SD card in the mobile device takes care of all the day/nights downloads.
Reconnect definitely seems to be the best solution for PC and I shall use it and dongle when/if I move to a pc based setup.
Which will happen sooner than later if this DHCP lease policy of 2 hours becomes a pain in the wrong place. Thanks Again!
ace said:
Thanks sanke1. Whats the workaround?
No workaround for that. If you write to some higher reps and if they are willing to increase the DHCP lease to 10 hrs like Triband, then it can work. But they must have arrived at 2 hr policy for a reason.
Thanks again sanke1. They have probably kept it at 2 hours to conserve on radio resources so I doubt it will change anytime soon.
I agree with you, there is little one can do about it unless the timer is extended.
Some how the folks on dongle seem to be less or not at all affected by this. How is that?
If you download using download accelerator, use resumable links. Some download accelerators/managers do not auto resume links unless you manually specify the number of retries when the connection is down during IP refresh phase.
Best is to use torrents and software like utorrent as it will resume download even after any amount of downtime. As long as you have healthy number of seeds, your download will always complete despite the disconnections.
In windows 7, you have to go to connection settings and enable re-dial if connection is dropped option. Windows 8 somehow did not have that option. So for windows 8, use a small utility called "reconnect software". Link below. Unzip it to some folder and after running, it sits in system tray and auto reconnects once it senses a dropped connection.
ReConnect for Windows
