Need help with configuration of huawei HG8145V5
  • Thread starter Thread starter Taz ryzen
  • Replies Replies 61
  • Views Views 18,577
I did not set up the voip profile.. just direct pppoe. Something has chang3d with airtel. Are you getting the same issue. That you get the wan ip but internet does not work?
Nope I'm not getting Wan ip either though I'm doing pppoe in pfsense. Changed SN but still. Not sure what is up, spent 2 hours yesterday on it. Will mess around more when I've time.
Can anyone check suddenly it started showing Beamforming as 1 for 5GHz WiFi
I've had bought a HG8120C from Varkey a few days ago. Will see if that one works. Clearly my issue is different from urs as u are getting ip address from pppoe. On mine pppoe server doesn't even show up. Very tiring.
Yes your right mine seems different than yours. Weekend is back, so my I will try to see of I could make it work today. 100th time is the charm hopefully
