Old PC starts and shutdown randomly within 2 seconds to 1 hour
  • Thread starter Thread starter amish
  • Replies Replies 48
  • Views Views 4,182
amish
Star gazer
I got banned!
Mumbai
MTNL Mumbai BB_600 @12mbps
So as I have been discussing in some other thread. I am planning to purchase new PC.
But before that I am just testing the old PC which I almost NEVER used. (harddisk used only for 45 hours in total)
I started this PC after like 8-9 years. But it looks completely brand new.
It has 3 fans in total. CPU Fan, Cabinet fan and PSU fan.
Here is what happens - randomly:
  1. I press power button, all fans start and switch off in 2-3 seconds (without beep sound)
  2. I press power button, all fans start and switch off after 5-10 seconds (after beep sound)
  3. I press power button, all fans start and OS boots (and then switches off from 2 mins to 1 hour)
  4. After switching off, it does not restart by pressing power button OR pressing reset button
  5. To restart either I have to turn off/on wall switch OR press power button for 7-8 seconds, release it and then press it again.
I was able to install Linux yesterday and then it stayed on for almost 1 hours (or may be little less) and then switched off directly.
I believe it is SMPS problem but just wanted to ask if there could be any other reason, like motherboard going bad etc.?
Thank you.
Photos attached - in case someone wants to have a look.
To install anything it should first boot OS and give me few minutes to do some testing.. but now it doesnt stay up for more than 2-3 minutes.. So it boots OS (once in 10 attempts or so) and then once it boots. I hardly get anytime to check anything
I dont have volt meter and i do not know how to use it.
So somehow the PC is running from about 20 mins
I ran linux sensors command and this is the output
As you can see temperatures are normal
At three places it is showing ALARM but I have no clue what it is. Or if those ALARMs make any difference
How do I read the voltages mentioned below? What is what?
# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +43.0°C (high = +76.0°C, crit = +100.0°C)
Core 1: +34.0°C (high = +76.0°C, crit = +100.0°C)
it8718-isa-0290
in0: 1.07 V (min = +0.00 V, max = +4.08 V)
in1: 1.63 V (min = +0.00 V, max = +4.08 V)
in2: 3.38 V (min = +0.00 V, max = +4.08 V)
+5V: 3.02 V (min = +0.00 V, max = +4.08 V)
in4: 304.00 mV (min = +0.00 V, max = +2.10 V)
in5: 4.08 V (min = +0.00 V, max = +4.08 V) ALARM
in6: 4.08 V (min = +0.00 V, max = +4.08 V) ALARM
in7: 3.12 V (min = +0.00 V, max = +4.08 V)
Vbat: 2.48 V
fan1: 1767 RPM (min = 0 RPM)
fan2: 0 RPM (min = 0 RPM)
temp1: -55.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp2: -2.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp3: +33.0°C (low = +127.0°C, high = +127.0°C) sensor = thermal diode
cpu0_vid: +1.100 V
intrusion0: ALARM
Does anyone have any idea?
EDITED:
After being up for 3 hours.. it finally shutdown abruptly
And now again .. it is shutting down within 2-3 minutes
Ok so machine is up from 2 hours now and seems like working properly
Today morning I attached a different power cable to machine
Can random shutdown be due to power cable?
But the point to note is that earlier also I had tested with a different power cable but problem was not solved...so i am wondering if both the previous power cables were faulty?
But if power cable were faulty then how did keyboard remained powered on even after random shutdown?
Check what? I had removed whole motherboard and reattached everything from scratch.
Since you are doubting Power Cable........... I said check the socket where you Plug the power cable...... try using some high wattage product, like an iron on that socket, if it works stable.....
