optivision router bsnl port forwarding need help
  • Thread starter Thread starter MEGAN
  • Replies Replies 21
  • Views Views 1,554
wan settings - nat -- post restricted cone NAT selected.
router have forward rules option -
what to fill in this external source ip add , port number which are blank
when i click select, it choose my computer name and automatically puts the internal host ip -- 192 168 100 2 where as my onu router is 192 ****** 1 .
ports need to be opened are 80 443 and some udp ports - they are closed in port checker websites .
when i ping the adress 74.201.103.238 -- this ip shows 100% packet loss , and request timeout . kindly do suggest what to do , thanks
@MEGAN How about trying to set your NAT Type : Open? When i try to ping 74.201.103.238 from NAT Type 4 (Restrict) i was also getting 100% packetloss but when i set my NAT Type 1 (Open) i'm able to ping the IP Address. (Ping : 180 - 200)
thank you for replying , in wan options - i see enable nat - then nat type opens - in this i see 2 options -- post restrcited cone nat and full cone nat
shoudl i disable nat totally ? and make a new wan ?
@Protector i tried with both settings, the internet access is there, but no sites open at all , the ping says request timed out , looks like the internet works only if i put nat port restricted cone nat
should i do anything with upnp ?
In that case, Port Forwarding option will also not work. (From my pov)
Full cone NAT is same like Open NAT.
But, Try for port forwarding.
Your router which I'm not familiar is different from mine.
I get many options at Port Forwarding. So, it will be better if someone with more reliable answer will response.
@sloj i gave some read into it , looks like my real ip in the router it shows in 100. something which means i am cgnat and double nated something - so port forward wont work and i need a static or public ip (i guess ) . so should i talk to bsnl guys /lco guys about this or anything with ip6 can be done ? any other ideas into this matter ,thank you
