.So i tried the DMZ Host technique and just added my IP adress in it and my icon in the utorrent showed green but still fopr a 2MBps connection I am gettin only 100kbps only if i put simutaneous downloads!!!!!!!!!!!!!!!!!
Wat to do???
Friend, if you have dmz'ed and still getting 100KBps, you wont be able to get more than if you do port forward. DMZ is a technique to forward all ports to that specific IP !
To get more speed, you should have more peers connected to you, They should allot more speed (in private trackers you will get better speed) !
So, try some private trackers and download when there are many seeders/leechers ! and check the speeds !
To appus
"The real problem is there coz i dont find a virtual server in my modem advanced page!!!!!!!!!!!!!!!!!" See tha pic below!!!!!
Check Under Advanced setup =>NAT=>virtual servers !
