Pls help me in Port Forwardin of UT 300R2U Router!!!!
  • Thread starter Thread starter frns4life
  • Replies Replies 69
  • Views Views 15,017
hehe.. i have one :yahoo::thumbsup:
by the way, can you post the device info page as well !!
Well to appus i always download from a site named darksiderg it has many seeders for axxo prints and i really have nearly 1200+ seeds but only get 100-120 connections and get speed upto 70kbps in tat site!!!!!! Well another site with private tracker namely tamiltorrents, wen i put their torrent to download i get nearly 80kbps and the fact is wen i put aqll downloads simutaneously i get 100kbps!!!!!!!!!
and for your info,
You maynot get connected to all the peers (seeders/leechers) most of the times.. But more the seeders, chances of getting speeds are more !
Well... I've a firewall and i am using my computer in DMZ mode (am OK with the security measures i have) ! I get up to 70KBps in private torrents (am on 256kbps ul) !
Are you getting better speed when u download files directly ?
http://img149.imageshack.us/my.php?image=63974971kz6.jpg
Have done it aapus.....
And to RIDAM have u seen the image of my modems home page......Yes u wont find virtual servers in tat advanced tab!!!!!
Nope appus!!!!!!!!!! Well tat too depends on the country's servers from which i get!!!!!Well maximum speed tat i get is 100-110kbps...........
https://broadband.forum/bsnl-broadband/21560-utstarcom-ut300r2u-firmware-anyone-please-help/
many have complained saying there is no virtual server in that tab :P
i wasnt aware of it ! if you get a new firmware, you can upgrade to it ! otherwise have to live with it ;) [dmz] !!
sorry for not helping you to solve the problem !!
so... if you cant get more speed in direct downloading (eg:microsoft. com), then you wont get more in torrents !!
last question. What speed you are seeing in speedtest . net ! use mumbai server !!! close all other downloading while running speedtest !
PROBLEM: TO ACCESS VIRTUAL SERVER IN utSTAR300R2U
os: vista. alternate ideas. telnet/hyperterminal
@/members/frns4life/
Windows Vista Help: What happened to HyperTerminal?
[Open in new window]
HyperTerminal is no longer part of Windows. There are several options you can use to replace its functionality.
• If you only need remote shell access, you can use WinRS (Windows Remote Shell), new in Windows Vista. To get help with WinRS, type winrs /? at the command prompt, and then press ENTER.
• Telnet is a simple, text-based program that you can use to connect to another computer over the Internet.
• If you previously used HyperTerminal to troubleshoot modem problems, use Phone and Modem Options instead:
•Open Phone and Modem Options by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Phone and Modem Options.
Sorry essbebe cant even understand a word can u?????Really very sorry!!!!:wall::wall::wall::(:(:(
If we can get it work with telnet, i will tell you how to enable telnet in Vista
Go to STart=>Control Panel
Open Program and Features
Click on Switch off Windows Features !
You will get a window where you can enable Telnet (scroll down a bit)
Telnet will be installed !
@ frns4life,
Can you just Check these info for me ! Since essbebe said you can do with Telnet, will give a try
Install telnet as i told above !
Now
1. Click on Run =>type cmd and get into command prompt
2. Type telnet 192.168.1.1 (your gateway)
3. give username /password
after that you will get main menu
press 6 (if that is NAT)
check there is a virtual server. if say, reply to this thread.. then will talk about adding it :P
Well give it a try in cmd but i tried and also installed telnet in vista but implications are tat i wasn able to proceed further!!!!! RIDAM said actually a white window will open where we can use cursor(tats for xp i think) but in vista its in dos mode!!!!Will also reply abt the methods u said aapus!wat is the username and password?????? Wat do i type in???? and if at all i type the username the password typed is not even shown!!!!! Wat to do????
if you are using telnet, it is a command window (black screen with white letters)
default password you give in when you give in your browser admin/admin ?
press enter after typing username, yeah, it wont show. still you know how to type without seeing it right ?
Above method i mentioned will install telnet in vista, i tried and got into the router with telnet. that is why i told those steps !! lets know once you done with it !
I pressed 6 it shows ""not found""!!!!!!!!!!!!! And it didn go into any main menu....Will i have wait for sometime?????
