Pls help me in Port Forwardin of UT 300R2U Router!!!!
  • Thread starter Thread starter frns4life
  • Replies Replies 69
  • Views Views 15,017
@/members/sreenidhibs/
SUMMARY : Posts 1 to 40. members/frns4life/
Problem :I cannot access'virtual server in my modem
OS:VISTA
to use telnet ( instructions given )
or hyperterminal. Now in vista WINRS equivalent program
References :
Port Forwarding - India Broadband Wiki
http://www.techenclave.com/guides-an...0bx-72916.html ( missing )
PORTFORWARDING BSNL /DATAONE UT300R2U MODEM | TechTricks
Port Forwarding for the UTStarcom UT-300R2U
PARA TWO: a wild try to open PF in UT300R2U
http://192.168.1.1/phtml/pmain.html
also try without "p" in the address. above.
@sreenidhibs
port fowarding will get more speed than DMZ ? I didnt know that. Read all his posts. For him, DMZ and direct downloading gives almost same speed ! So if he remove DMZ and port foward, will he get more speed ? I am not aware of it !
[friends, this has to reply only by the above person... i know what is DMZ n port forward.]
Direct downloading and torrent speed differs in either way...
Torrent
If there are less seeders and they keep upload speed less, you will get less than what is expected.. even much less than direct download !
If there are many seeders and many leechers, you have a chance of getting the maximum speed !
Direct Downloading
If there are more people downloading the same file from same server, chance of less speed..
If there are less people downloading the same file from same server, you can get the maximum speed !!
And, finally.. you havent told about putting the screenshot in this site.. for that, we have to come to your blog.. ! Keep it up !!
@essbebe,i have confirmed that BSNL provided newer ut300r2u don't have port forwarding option & you can't use the link trick in this modem too because BSNL is using scripts to hide the url links by not using a simple html page in configuration.here is a source code(firefox--->ctrl+U) of configuration page of ut300r2u which you can see is completely different from a normal html page for,say,your modem---
DSL Router
hey whitestar there are two UT300R2U's .. the one above is UT300R2U but there is another utstarcom ut300r2u.. theres a bit of confusion i guess regarding this.. it maybe possible with the utstarcom one!!
@/members/superprash2003/
As you said, most of them seem similar, except for one model.
@members/whitestar_999/: You are giving too much credit to BSNL.All the modems/routers they order are on lowest quotation basis !!!May be the contracted company imported and
supplied a batch with faulty firmware !!which BSNL staff did not notice/did not know !)
Recently same problem for Sl2_141 was reported and @ridam tried telnet/hyperterminal etc.
( usual blaming of BSNL )
After my suggestion now he can access PF page ( virtual server) directly in modem.
I gave the suggestion because the FW appeared similar to beetel 220BX.
Para two : Only a person , who has UTSTAR 300R2U with Virtual server option available, can tell the web address. such as 192.168.1.1/index1/main.html etc to show Advanced options.
Para two:
By the way, my very first post in IBF was about PF in Beetel 220BX for an application called Echolink, and I learnt about this main.html option only then.! Unfortunately all my old posts ( 1 to 3600 are gone/deleted/ and only latest 500 posts are availble. ( 20pages x 25 posts)
@sreenidhibs
Torrent
Direct Downloading
"port fowarding will get more speed than DMZ ? I didnt know that. Read all his posts. For him, DMZ and direct downloading gives almost same speed ! So if he remove DMZ and port foward, will he get more speed ? I am not aware of it !"
when did i say this?
portforwarding wont get more speed than what you already get in dmz.
dmz(demilitarisedzone) opens up all the ports.
its obvious!!(but again it depends!!direct downloading ;;which site??)
he definitely wont get more speed.
Torrent
Direct Downloading
perfect explanation!!cant get simplet than this!!:thumbsup:
"And, finally.. you havent told about putting the screenshot in this site.. for that, we have to come to your blog.. ! Keep it up !!"
thank u!:thumbsup:
my dear friend ,i am a member of not only this forum ,but couple of other forums too,imagine puttting screenshots in every forum.!!!!!
but u might say ,u can copy/paste things ,but still it takes time and patience neither of which i have in excess.
moreover, my content has helped many of them,its worth trying out,than giving up.
hope it explains!!!
Problem :OS:VISTA
References :
also try without \"p\" in the address. above.
yeah i got the point.youve got a and old firmware.ill get you detailed explanation of setting it up for pf in a few days(having exams:()
PROBLEM: VIRTUALl SERVER NOT SEEN IN ut300r2u
What BSNL has allegedly "hidden" same code as posted by you function also same.
Beetel 220BX1 is showing with same "hidden" code Virtual server &port triggering.
see the function
see the function
Now if you paste the same code with the original page and IE address, I think
UT300R2U Advanced options will be accessed easily./
http://i29.tinypic.com/30b0nrp.jpg
Para two: EUREKA ! CAN WORK FOR ONE MODEL.
TRY 192.168.1.1/menu.html
http://192.168.1.1/menu.html
http://192.168.1.1/scvrtsrv.cmd?action=view
NAT virtual servers
http://192.168.1.1/scprttrg.cmd?action=view
NAT port triggering
http://192.168.1.1/scdmz.html DMZ server
Para Three: other pages (samples)
http://192.168.1.1/info.html device status
http://192.168.1.1/dnscfg.html dns server
http://192.168.1.1/wancfg.cmd
http://192.168.1.1/statsadsl.html ADSL STATS
@essbebe,i made this suggestion of bsnl hiding exact links is because source code for ut300r2u is based on comparisons with siemens modems which i am familiar with.
@members/whitestar_999/: You are giving too much credit to BSNL.All the modems/routers they order are on lowest quotation basis !!!May be the contracted company imported and supplied a batch with faulty firmware !!which BSNL staff did not notice/did not know
if bsnl is inviting tenders or for that matter any company it is free to dictate any terms & conditions & assuming bsnl dictates in the tender that firmware should be with some modifications/restrictions companies will only oblige to get the tender.i seriously doubt any company will made/produce modems which require tricks to access their supposedly advanced functions as simple as port forwarding if company cares even a bit about it's reputation in retail market which clearly is not the case in OEM market.older ut300 modems with advanced options available,newer modem provided by bsnl including siemens c2110,ut300r3u,siemens sl2_141 all requiring tricks to access port forwarding simply a coincidence??i don't think so.companies as different as starcom & siemens making almost similar so called faulty firmwares across a wide range of modems.i.e.type I/IV(port forwarding not available)!!
