i remember some guy from my area trying to get a new beam connection in our area and was blocked my local cablewallahs.....will check other sites and update....
BTW i did use cmd with administrative privileges...:/ still ip didnt get release..
netant
One more thing to check if ipconfig /release has been successfully worked or not.. once you did /release wait for 10 second and again run /release .. it should throw you an error that no network adapter found or similar error.
yea.. i tried this too..waited for 5-10 secs and tried again..no such luck.. :S
and i got this new doubt....since u ppl connect to beam portal....your ip address is automatically configured rite..?!( i mean "get new ip automatically " option is enabled in internet properties window rite..?!)
with my connection i should enter the ip given by my beam local wallah...so ..i get one permanent ip right..!?!?? WTH.?!
I remember my technician telling them Beam stopped using 24x7 sometime back... now they only use http://portal.beamtele.com/
i tried opening this site..still getting the below error!! :S
http://anony.ws/pt-2HCL.html
netant
