problem "IP address coflict with other useron network"
  • Thread starter Thread starter sau100
  • Replies Replies 2
  • Views Views 1,693
sau100
bsnl
from 2 day my system is showing error" IP address conflict with other user on network" this is when i connect to net....please tell me the reason and solution to prblem
Please give full info.As:Do you have static IP?Is your PC the main server through which other people connect to the internet?---------------------------------------------------------------------------------As of now Check whether LAN properties have TCP/IP Settings as to "Obtain IP Automatically" or there is a default IP given.
Do you use the Broadband on 2 Computers?If so then both computers are set to acquire the same IP address.The IP address to acquire is set when you configure Port Forwarding.
