Hi Guys ...
All products sold in US are not compatible with European standards and Asian Standards. In Indian subcontinent we use the PAL B and PAL G system. Whereas US uses NTSC 3.58 and Japan uses NTSC 4.43 system. Before you buy any product from JAPAN & US which involves VIDEO, check it supports PAL standard too.
Tata Sky uses PAL G Standard. INFO given by CC is Bull Shit:evil:.
Signal is protected till the time it enters the STB, after it is decoded and once out thru RF, RCA, S Video or Composite its free.
Check your video setting on Recorder. If it supports PAL its OK. Otherwise here is an experiment you can do if your
TV supports NTSC playback
Connect to
Digicomp AV out >>>>> RECORDER AV IN >>>>> MODE NTSC >>>>> Record it >>>
Playback on TV in NTSC Mode.
I doubt it..
OR you need to buy a Converter
Have a Detailed Info of PAL NTSC and other standards
NTSC and PAL Formats
NTSC
NTSC stands for the National Television Standards Committee. It is a video signal standard used by the color television industry in the United States and Japan.
The NTSC is a common format used by many video compression boards.
NTSC video contains frames and fields. Most NTSC video frames consist of two interlaced fields. Each field is displayed as alternating horizontal lines across the screen. Most computer video formats are non-interlaced.
The frame aspect ratio used by the NTSC standard format is 4:3. This format uses a 640 by 480 resolution.
By using the NTSC standard for digital video, there are two areas of concern when dealing with aspect ratios. They are as follows:
Pixel aspect ratio
· Frame aspect ratio
[/list]There are various divisions within the NTSC standard which determine what pixel and frame aspect ratios are used. These formats are as follows:
[*]· NTSC (resolution 648 x 486 - preferred format)
· D-1 NTSC (resolution 720 x 486)
· D-1 NTSC Square Pix (resolution 720 x 540)
[/list]NTSC (Preferred Format)
This NTSC format uses a 648 by 486 resolution format. This format makes an allowance for a few additional pixels to be created on the screen edge that may be cut off when displayed. This format is also commonly used by many video compression boards.
Because this format allows you to display a video without losing the "edges" of your video during playback, this resolution seems to be the preference within the industry.
D-1 NTSC
The D-1 NTSC format uses the same standard frame aspect ratio as the NTSC format. Unlike the NTSC format, the D-1 NTSC format uses a 720 by 486 resolution using rectangular pixels.
The D-1 pixels used in the NTSC format are displayed using a vertical axis.
D-1 NTSC Square Pix
This format uses the same standard frame aspect ratio as the NTSC format. Unlike the NTSC format, the D-1 NTSC Square Pix uses a 720 by 540 resolution using rectangular pixels.
PAL
PAL stands for the Phase Alternating Line. This is a video standard used by the color television industry and is the common standard used in Europe. This video signal format sets the video to playback at 25 frames per second which contain 625 lines of pixels in each frame.
There are various divisions within the PAL standard which determine what pixel and frame aspect ratios are used. These formats are as follows:
[*]· PAL (resolution 720 x 486)
· D-1 PAL (resolution 720 x 576)
· D-1 PAL Square Pix (resolution 768 x 576)
[/list]D-1 PAL
The D-1 pixels used in the PAL format are displayed using a horizontal axis. This format uses the same standard frame aspect ratio as the PAL format. Unlike the PAL format, the D-1 PAL uses a 720 by 576 resolution.
D-1 PAL Square Pix
This format uses the same standard frame aspect ratio as the PAL format. Unlike the PAL format, the D-1 PAL Square Pix uses a 768 by 576 resolution using rectangular pixels.
HDTV (1280 x 720)
The HDTV stands for High Definition Television. This format is a proposed definition which displays at 1280 by 720 resolution.
HDTV (1920 x 1080)
The HDTV stands for High Definition Television. This format is a proposed definition which displays at 1920 by 1080 resolution.
Film (Academy)
This format uses 2048 x 1536, a standard resolution used for digital film.
http://cgi.ebay.in/Play-Station-2-P...categoryZ62053QQcmdZViewItem#ebayphotohosting cost Rs 990 on
EBAY but they say it will convert PAL to NTSC for gaming console as it include only Video
will work for you
